Problems charging
Like Tree4Likes
  • 1 Post By Grasshopper77
  • 3 Post By RVC
Old 18 Oct 2019, 04:50 pm
RVC RVC is offline
Default Problems charging
I recently bought a basic 2006 with about 64.5k miles on it. The only problem encountered so far has been the charging system. I put a new battery in it, fully charged, and when I try to crank it the instrument panel goes blank, it doesn't crank and there are no other sounds.
There is probably a simple explanation for this but so far I haven't found one. Knowledgeable suggestions will be most helpful.
Thank you.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 18 Oct 2019, 05:00 pm
Default Re: Problems charging
I'd start by checking the battery cable connections on bother ends, as well as, the entire length of the cables. You are not getting a good connection or there is a problem within the ignition system. Hopefully someone a lot more knowledgeable will stop in to offer some better advice.
Handy_Cruiser likes this.
Old 18 Oct 2019, 06:58 pm
Best guess is a short, possibly in the starter. Alternator charging in 2006 is controled by PCM. Check wires on starter, there is green wire than easily be attached to the wrong terminal getting a no crank condition.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 18 Oct 2019, 07:23 pm
Checking the connections, as suggested above, is where to start. If the connections are clean and tight, I'd do a load test on the battery to verify it's OK. Then the next step is going over it with a voltmeter. If you're not handy with a voltmeter, find someone who is. Basically checking voltage levels to check cable & connection integrity.
The fact that the dash goes dark when you try to start it indicates the system voltage dies when the key hits the crank position. The question is why does the system voltage die? Could be a discharged battery, bad battery, bad connection, bad cable, or too much load on the battery.
Old 19 Oct 2019, 08:12 am
It sure sounds like a loose ground connection to me. I'd remove the air box assembly and check the grounds on the driver side fender AFTER checking the battery ground cable for a tight connection.
Old 19 Oct 2019, 09:30 am
RVC RVC is offline
Thanks for the replies. As soon as the rain and wind die down here I'll be on it.
RVC
Old 23 Oct 2019, 12:38 pm
RVC RVC is offline
Turns out it was the terminals, especially on the ground side, but none of them were in very good shape. Thanks for the input.
RVC
Old 24 Oct 2019, 07:37 am
So, you've fixed it and you're good to go?
Old 25 Oct 2019, 11:46 am
RVC RVC is offline
Yep, for now anyway. But it's been sitting up for a while so who knows what's next. Thanks!
RVC
Battery Charging problems. nebular Tech & Performance Forum 11 23 Jul 2018 11:50 am
Charging system robmet55 Tech & Performance Forum 4 22 Jun 2012 11:18 pm
pt not charging. eli Tech & Performance Forum 1 30 Jul 2011 02:03 pm
charging problems with 01 pt cruiser gdxxman General PT Cruiser Discussions 3 11 May 2009 04:59 am
UK crd charging question spiceweasel Tech & Performance Forum 6 15 Dec 2007 04:37 pm
