can my idle control valve be cleaned
Old 10 Nov 2019, 06:21 pm
Default can my idle control valve be cleaned
i have a 2007 pt cruiser convertible , once warm the idle is erratic, it can be fine for a few minutes then the engine drops so low it feels like its going to stall , i want to know if the idle control valve can be cleaned or does it need to be replaced
Old 10 Nov 2019, 06:26 pm
LionPT's Avatar
Default Re: can my idle control valve be cleaned
It needs to be replaced. You can't clean the G2's 2006-2010.
Old 11 Nov 2019, 08:34 pm
ok , thank you
Old 14 Nov 2019, 03:49 pm
thecabinguy's Avatar
My PT started acting the same way, even the idle going down and starting to run rough. Turned out it was my high speed fan gone kaput when trying to use the A/C. New fan and all was right with the world.
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Old 17 Nov 2019, 06:31 pm
i did try turning my ac off to see if it still did it and it was better but still felt like it would almost stall, i did change the idle control valve(5 minute job) but haven't driven it yet
Replaced the IAC Idle air control valve? Special tool needed? worcestersauced Tech & Performance Forum 14 04 Apr 2016 01:22 pm
Idle Air Control Valve chuzz General Turbo Discussions 7 17 Oct 2015 10:08 pm
After An Idle Control Valve scotty68 Europe PT Forum 5 11 Aug 2014 09:21 am
Cleaned my Idle Air Controller Now Car Overheats 52smooth Tech & Performance Forum 3 22 Aug 2013 05:55 pm
Idle Air Control valve stan6406 Tech & Performance Forum 5 02 Feb 2012 06:02 pm
