Where are the fan relays?
  • 1 Post By RVC
Old 23 Nov 2019, 08:02 am
RVC RVC is offline
Default Where are the fan relays?
Good morning.
I'm working on a newly acquired '06 with 64.5k miles. The engine is running hot and I figured I'd check the fan relays first (easiest to reach). There are 2 sets of relays - one set on the fan shroud on the passenger side and the other above the shock tower on the driver side. Both sets have the same part number. Which are the ones I should check? Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 23 Nov 2019, 08:26 am
Default Re: Where are the fan relays?
Since they're all the same number, I'd just try swapping one at a time and see what happens. 06 is the first year for the TIPM, so I'm not sure what you've gotten yourself into. If I were going to test relays, I'd start with the ones on the fan shroud, but that's just my way of thinking as I know NOTHING about the TIPM setup except that I don't like it. Good luck with it and I'm sure one of the smart members will tell you what to do.
Old 23 Nov 2019, 09:24 am
LionPT's Avatar
Originally Posted by RVC View Post
Good morning.
RVC
It's the 2 on the fan shroud.
The other 2 are the Starter Relay & the Auto Shut Down Relay.
Old 23 Nov 2019, 01:38 pm
RVC RVC is offline
Thanks, Lion. See you're still flying the P51, there Chuzz.
RVC
chuzz likes this.
Old 24 Nov 2019, 03:23 pm
Fan motors are very suspect and not very expensive for complete fan assembly
unless its turbo.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 24 Nov 2019, 11:52 pm
Codes?
Ecm not grounding some relays PTgurls Gulf PT Forum 1 28 May 2017 08:24 pm
A/C Fuses and Relays. dwt83 Tech & Performance Forum 11 04 May 2017 05:26 pm
Relays Pthobbit Tech & Performance Forum 4 06 Mar 2016 04:03 pm
Coolin Fan Relays euphonium_john Tech & Performance Forum 2 19 Apr 2014 07:53 am
Fan Relays - How Do You Disconnect Them? AlphaBob Tech & Performance Forum 5 09 May 2011 01:43 pm
