Oil Disappear
  • 1 Post By FeelthySanchez
Old 28 Dec 2019, 09:09 am
Default Oil Disappear
Morning folks,
I have an 08 Cruiser, non-turbo, that has been losing oil on the dipstick check. No visible leaks I can find, no oil from being parked in driveway,
68k original miles. Always syn oil at 3000m
Adding 1/2 quart 3/4 weeks.....could it be pcv related? Ordered the valve and hose just in case it is. Thanks for your input
Old 29 Dec 2019, 08:28 am
Default Re: Oil Disappear
Of course that's a possibility. Take a close look around the valve cover and oil pressure switch too.
Old 30 Dec 2019, 01:31 am
Is your engine compartment severly hot after driving it to several places? If so is ur CAT an aftermarket CAT?
Old 01 Jan 2020, 04:45 pm
FeelthySanchez's Avatar
Not likely. The more usual suspects are worn valve guides &/or piston rings.
Do the plugs show any signs of oil or residue?
Originally Posted by Wagondog View Post
.... No visible leaks I can find, no oil from being parked in driveway, 68k original miles. Always syn oil at 3000m. Adding 1/2 quart 3/4 weeks..... could it be pcv related? t
Orig owner 100% stock Patriot Blue 2001 LE 5-spd: 283,760 miles & rolling well on it's 3rd ECM, 2nd engine, 3rd gearbox, 2nd rack & pinon.
"The idiot's guide to passing yourself off as leadership" - Ed Hipalito. Author, mgmt failure, narcissistic buffoon.
Old 02 Jan 2020, 12:36 pm
I agree with the valve guides with the CAT overheating the engine head damaging the valve guides. Bad design from Chrysler.
Both of my Pt Cruisers have the same problem since I
bought them nine years ago. Try using regular engine oil instead of Mobile one synthetic oil.
