Crankshaft Damper/Sprocket Installer 6792?
Like Tree3Likes
  • 1 Post By rambojoe
  • 2 Post By myckee
Old 28 Dec 2019, 09:39 am
Default Crankshaft Damper/Sprocket Installer 6792?
Do most of you use or have access to this tool when reinstalling the lower sprocket and/or crankshaft damper pulley?
I've used the old school method of heating the sprocket/damper and simply pushing it in fully into place. Both stop with a clunk at their inner limit.
I have noticed there is a grove in the crankshaft that could be there for reference. The sprocket easily pushes past the grove before hitting the clunk spot.
I guess I'm asking if this is too far?
Or should I be seeking out the special tool? If so, where would I find one?
Bob in Liberty
Old 28 Dec 2019, 09:05 pm
Default Re: Crankshaft Damper/Sprocket Installer 6792?
The only one worth buying is a hydraulic installer.
The one you are referring to is just a costly way of using the bolt and a socket....with a hydro unit you dont even need to heat the damper- it goes quick and generates its own heat via friction.
Old 05 Jan 2020, 12:30 pm
At your local parts store, you can rent a "long reach harmonic balancer install tool". It is free to rent. The nut has a bearing incorporated into it and it will easily push the balancer/sprocket on with almost no effort. No heating and no pounding etc. The tool is free to rent around here. If owning one is your thing, you can buy one on ebay or amazon for $30-40. It will work on multiple engines and brands.
Handy_Cruiser and chuzz like this.
Old 06 Jan 2020, 02:48 pm
Bob in Liberty
Bottomed out. Torque as per manual.
Crankshaft sprocket removal process Bandit2014 Tech & Performance Forum 15 03 Oct 2016 04:56 pm
Crankshaft damper removal tool/baring puller Marty_D General PT Cruiser Discussions 4 18 May 2013 07:07 am
Do you need to remove crankshaft sprocket? unioncreek Tech & Performance Forum 14 19 Jul 2012 09:24 pm
Crankshaft damper won't come off!! able2able Tech & Performance Forum 7 03 Jun 2010 09:48 pm
Need help finding dealer/installer SC / Turbo xyster Western PT Forum 5 18 Dec 2005 08:01 pm
