Tomorrow head gasket job
Like Tree14Likes
Old 30 Dec 2019, 09:15 pm
Default Tomorrow head gasket job
Tomorrow around noon I値l start on my head gasket job.
Going to try and bang it out quickly. I知 putting a new timing belt and water pump on as well.
I don稚 plan on resurfacing the head at all. I値l put a level on it and inspect it.
This will be the last time I値l do this job on the car. I also need front wheel bearings but I値l hold off on that till this is done
2001 non turbo. Auto
Old 31 Dec 2019, 02:13 am
Default Re: Tomorrow head gasket job
I hope you meant a straight edge, a level is no where close enough to check for a warped head.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 31 Dec 2019, 08:13 am
Don't forget that center motor mount while you're in there. Unless you've already replaced it once before. At least take a look at it.
Old 31 Dec 2019, 08:45 am
I was meaning strait edge.
I値l check the mount. It痴 been changed before. I知 trying to not go overboard on the cost of fixing this thing. It痴 probably only worth $800 fixed
rockandroller likes this.
Old 31 Dec 2019, 12:03 pm
I知 half way to Orlando. I came from Tampa, the car seems to not be ore heating at all now. I filled it up with water and expected to have to call AAA but it痴 holding steady. Very weird. I had replaced thermostat. Filled with water multiple times. Bled the system
I think I知 still going to change it. See how it goes the rest of the way
Old 31 Dec 2019, 10:06 pm
If you do not skim a head that has had any over heating issues, it will simply be a waste of time...
You do not need to pull the valves at all. And your local cylinder head guy can vac test all your valves at the same time. All for 80$
Old 01 Jan 2020, 08:30 am
If you're just running straight water, then the odds of it overheating are much higher. You really need a 50/50 mix of water and anti-freeze, no matter what time of year or how cool the temps are. From my point of view, yesterday was perfect. 65 degrees here with low humidity. I got a lot of yard work done and will continue today with the beautiful weather we're having right now. Take advantage of it and get the head gasket job done now. It's supposed to rain and get warm again in the next few days. I'm about 120 miles from Clearwater off Highway 60 in Polk County. Do you guys know where Yeehaw Junction is? I'm between there and Lake Wales city limits.
Old 01 Jan 2020, 11:47 am
Many do not really know how to "properly" use a straight edge on a head or engine block. It really is not as simple at may appear to be procedure!
Old 02 Jan 2020, 12:59 pm
Only if you have done the procedure before.
Old 02 Jan 2020, 07:08 pm
Update. Taking longer than expected
Water pump was almost wore out. Glad I got a new one
Top motor mount was bad. Got a new one
Currently drinking heavily, trying like hell to get the timing right
Sighh
LionPT likes this.
Head gasket going on friends PT. Is a gasket seal additive a decent last ditch fix? ptprice General PT Cruiser Discussions 24 10 Oct 2018 06:07 am
PT Getting New Cylinder Head, Head Gasket, Water Pump. What Could I Mod? 06turbolite Tech & Performance Forum 8 14 May 2013 09:16 am
03 pt turbo oil in water new head gasket fresh head strokedoutss General Turbo Discussions 7 17 Apr 2013 04:22 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
