PT Cruiser Forum Car Videos
Custom Wheels
Power Steering talking back (?)
  #11 (permalink)
Old 22 Feb 2003, 03:48 am
MichaelDay MichaelDay is offline
Try this:
TSB# 1900601A (Component: Steering: Column - Experiencing steering column click sound when the steering wheel is turned).
It is probably the clockspring in your steering column. Seems to be a hot topic of discussion all of a sudden.
2003 Almond GT
  #12 (permalink)
Old 28 Feb 2003, 07:12 am
theoddcouple826 theoddcouple826 is offline
When I had 2300 miles on my pt something happened when i was driving down the street and it ground and binded and made the worst noise. It turns out that something happened with my power steering. I got it into the dealer and they fixed it that day. They told me that the power steering pulley in is another pulley with a rubber washer or bushing connecting the 2. To this day 11000 miles later still squeels and some times doesn't work.
  #13 (permalink)
Old 28 Feb 2003, 12:04 pm
Update on my rubbing sound when even slightly turning the steering wheel:
Took it to my 5-Star dealer. They worked on it for a couple of hours, lubricated the point where the steering column goes through the boot and said "we took it for a 4 mile test drive, it's fixed."
I drove it 4 feet and it started doing the same thing it had done before but not as loud. Got the service writer to take it back into the shop to try again. After another 15 minutes they determined that they really didn't know what the problem was. Said they would have to call Chrysler's support group and then they might have to order parts. I left with the car and they called me about 45 minutes later to say that support was aware of the problem and they were ordering Krylox (part # 5049059AA) to use on the rack and pinon. I will be taking my GT back on Monday to have the work done.
I'm keeping my fingers crossed. I love the car looking loke a 37' Ford, I just don't want it to sound like one.
2003 Almond GT, body colored rear splash guards, hood struts and front license plate frame, rear MOPAR door sills
  #14 (permalink)
Old 01 Mar 2003, 01:14 am
ptcignaboi ptcignaboi is offline
Michelleday
Please keep me posted on what they do. I think I am having the same problem. Explain to me where the noise is coming from? Is it where the steering meets the transmission in the compartment?? Mine is still making the chirping/squeeking sound as I turn right or go over bumps. I took it to the 5 star dealer and they keep telling me they cannot hear it. But the second I drive off the lot, squeek squeek squeek. It's driving me nuts.
Thanks
  #15 (permalink)
Old 02 Mar 2003, 01:00 pm
dxhogg dxhogg is offline
quote:
It's cold outside. I turn the steering wheel off center to take a turn and hear (and feel) a mild grinding noise. If I turn and hold the wheel at a stop, same thing. HOWEVER it does not do this all the time.
Have any of you had a bad power steering pump?
ray
  #16 (permalink)
Old 02 Mar 2003, 01:02 pm
EVERY ONE OF THESE CRUISER'S COME FROM THE FACTORY WITH THE POWER STEERING RESERVOIR LOW ON FLUID IT IS IMPERITIVE THAT THE FLUID LEVEL BE TOPPED OF RAY
ray
  #17 (permalink)
Old 02 Mar 2003, 01:04 pm
ray
  #18 (permalink)
Old 02 Mar 2003, 01:10 pm
quote:
I also have recently noticed that when I turn the steering wheel slightly from one side to the other on my GT, I get a sound like rubber squeaking. I have checked the power steering fluid and it is on full.
Will probably take it to the dealer next week although I hate letting it out of my sight.
2003 Almond GT
HI I HAVE TO LAUGH AT SOME OF THE EXCUSES THAT SOME OF THE DEALERS GIVE FOR THIS PROBLEM THAT YOU ARE HAVING I WORK FOR A CHRYSLER DEALER AND YOU MUST TELL THE YOUR DEALER THAT IF HE LOOKS UP ON THE MDS2 FOR THE TSB RELATING TO THE STEERING NOISE IT WILL GIVE HIM A PART NUMBER TO ORDER AND FIX YOUR PROBLEM....WHAT IS HAPPENING IS AT THE BASE OF THE STEERING COLUMN IS A BEARING THAT ALLOWS THE STEERING SHAFT TO ROTATE AS YOU TURN THE STEERING WHEEL AND THE BEARING IS ACTUALLY SNAPPING AS YOU ROTATE THE WHEEL IF YOU CANT GET ANY SATISFACTORY RESPONSE FROM YOUR DEALER E MAIL ME AND I WILL E MAIL YOU THE TSB NUMBER RAY
ray
  #19 (permalink)
Old 03 Mar 2003, 04:16 pm
The noise in the steering column continues. Dealer put in the Krytox lubricant and it didn't help (what a surprise!!). They called STAR and were told to replace the rack and pinion. Parts are on order and should be in toward the end of the week. I will provide an update when they complete the replacement.
  #20 (permalink)
Old 05 Mar 2003, 02:37 pm
Squid Squid is offline
Had the same problem. Took my cruiser to the dealership. Give the TSB on the clicking sound. They replaced the parts. Now the it is quite again. Plus it stop the howling from the power steering unit.!!!
vB code is On
Power steering whine problem identified sawdust123 General Turbo Discussions 4 10 Aug 2005 02:03 pm
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Back power window switches not working lumofny Tech & Performance Forum 3 16 Jan 2005 10:00 pm
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  Final Fantasy Wallpapers | Don Omar | Loans | Free Advertising | Credit Check
