Overheating and then cooling off
Old 20 Mar 2020, 05:36 am
Default Overheating and then cooling off
On my 2006 PT with the 2.4 NA engine, I recently replaced my Stant thermostat with a genuine Mopar thermostat because the engine would not reach normal operating temperature. Today, the first time I made a longer trip, the temperature started climbing above normal, and the warning light started flashing. A little bit later, before I could exit the freeway I was on, it started cooling off and reached the normal temp. The outside temperature was -1 C.
Does anybody have a clue, what happened?
Old 20 Mar 2020, 07:35 am
Default Re: Overheating and then cooling off
Sounds like you may have had an air pocket and it purged itself via the radiator cap and overflow bottle. I'd suggest your check your coolant level and top it off if necessary. Keep in mind I'm NOT a mechanic, though, so you may want to wait for other answers.
Old 20 Mar 2020, 01:50 pm
Yes check your overflow bottle and make sure it is filled to the fill line, A weak radiator cap is another possibility, as the engine gets hot coolant expands and should go into the over flow bottle and as it cools water is drawn back into the cooling system. It takes a while to get all the air out of the cooling system, avoid overheating that will cause leaking head gasket and you don't want to go there.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 20 Mar 2020, 03:02 pm
First I would test the thermostat in almost boiling hot water. Rejoice if it's bad because the alternative could be bad news.
Tags
overheating, thermostat
Cooling Fan donsr1964 General PT Cruiser Discussions 3 05 Sep 2013 06:36 pm
AC not cooling mheff General PT Cruiser Discussions 13 30 Jun 2013 09:48 pm
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
01 overheating w/ new cooling fan Kate Tech & Performance Forum 2 23 May 2013 11:10 pm
Cooling fan... need help Jimmyo General PT Cruiser Discussions 4 06 Jun 2010 10:54 pm
