No start after new timing belt
  #11 (permalink)
Old 26 Mar 2020, 10:59 am
LionPT's Avatar
Default Re: No start after new timing belt
Originally Posted by chuzz View Post
Are you sure you got the wires back on the starter correctly? Not trying to piss you off, just asking a question that COULD be the problem if the small wires are in the wrong place.
Check the green wire.
  #12 (permalink)
Old 26 Mar 2020, 11:02 am
Yes Wires are on correctly. Battery and alternator on the big post. The pull in wire is a push-on [ not a ring terminal ].
  #13 (permalink)
Old 26 Mar 2020, 11:06 am
I will check the green one
  #14 (permalink)
Old 27 Mar 2020, 02:17 am
I would suggest pulling the starter relay and see if you have voltage coming from the ignition switch when you turn the key to start the Pt Cruiser.
  #15 (permalink)
Old 27 Mar 2020, 07:06 am
I'm going to check some more today and I will check the start relay and adjust the shifter.
  #16 (permalink)
Old Yesterday, 02:15 pm
Well I haven't worked on the no start problem for a few days. Anyway today I pulled the start relay and jumped from the 12 volt in source of the relay coil over to the solenoid socket that goes to the starter and the engine cranked with the key in the run position. Still no start and no spark though. I checked the socket coming from the key switch in to the relay socket and only had 3 volts.
Something is blocking the power from the key switch [a bad or green connection] to the start relay. Just have to continue the search.
What does the shutdown relay do??
I thank everyone for the help so far and hoping everyone doesn't get this virus.
  #17 (permalink)
Old Yesterday, 02:33 pm
LionPT's Avatar
Automatic Shutdown Relay
The power supplied to the fuel pump, ignition coil, fuel injectors, and parts of the power module is controlled by the logic module through the Automatic Shutdown Relay (ASD); the idea is to shut off fuel pressure and the ignition systems when the key is turned off to prevent fires, dieseling, and other problems.
  #18 (permalink)
Old Yesterday, 02:58 pm
Thank you for that info.I can understand how that works but when the key is turned to the on position the fuel pump runs and sounds like it always has. Wouldn't that rule out the Automatic Shutdown Relay as a possible problem ??
  #19 (permalink)
Old Yesterday, 04:57 pm
LionPT's Avatar
Yep
Right next to that is the starter relay...you can switch that out with a fan relay to see if it's good.
No Start After Timing Belt mtyson General PT Cruiser Discussions 4 03 May 2019 04:53 am
About to start timing belt job! fisheyestudio Tech & Performance Forum 5 22 Jul 2016 01:13 pm
After timing belt wont start moparman75 Tech & Performance Forum 1 17 Apr 2011 10:39 am
timing belt/ no start/ no compression sylster General Turbo Discussions 8 01 Mar 2010 08:42 pm
timing belt no start YouPutz Tech & Performance Forum 17 27 Feb 2010 04:38 am
