I would suggest checking fuse #1 in the PDC.
If at First You Don't Succeed - Try, Try Again |
ok, will do
Green wire #4 Make sure #3 is on the left plug if your starter has a left & right. #4 should send power to fuse panel/TIPM. #3 is power from key to the starter solenoid.
![]() 2006 Touring Edition in Cool Vanilla...aka/Ghost |
It's not getting full voltage to the #3 wire and no spark
Can't remember what it was but there were lots of reports on here about ignition lock unit problems at one time.
Yes, I have that also. Got to adjust that.
Ok, back on the PT cruiser after a couple months of " honey-do" jobs. I had no luck on getting the engine started but I was talking to a good friend and his son works on all cars and he has a high tech scanner. He hooked it up and said he cannot access the Ignition module which is the reason I have no crank and no ignition spark. My question is " is there a fusible link that could be blown on the power to the ignition module [ computer]? Other wise I apparently need a new computer module and where is it located?
I don't know if I can get one for a 15 year old car. ![]() Everything previously suggested by everyone has been checked. Last edited by nicky1; 29 Jun 2020 at 07:18 am. |
I would suggest unplugging the camshaft sensor connector and see if you get a spark. There might be a timing issue.
It's worth a try
On a Neon I had a bad ignition switch. It behaved pretty much like this.
Thread Tools | |
Display Modes | |
No Start After Timing Belt | mtyson | General PT Cruiser Discussions | 4 | 03 May 2019 04:53 am |
About to start timing belt job! | fisheyestudio | Tech & Performance Forum | 5 | 22 Jul 2016 01:13 pm |
After timing belt wont start | moparman75 | Tech & Performance Forum | 1 | 17 Apr 2011 10:39 am |
timing belt/ no start/ no compression | sylster | General Turbo Discussions | 8 | 01 Mar 2010 08:42 pm |
timing belt no start | YouPutz | Tech & Performance Forum | 17 | 27 Feb 2010 04:38 am |
