I have an 05 Cruiser 2.4 Turbo convertible that i have changed the timing belt,water pump etc on. I know the engine is in time correctly but it will not start. As a matter of fact it wont crank from the key switch [ the solenoid just chatters like a dead battery but if I run a jumper wire and touch the solenoid pull in It will crank but no spark. I have removed the grounds on the left inside fender, cleaned them and still no change. I even ran another ground from the engine block to the ground bolt. I checked the codes on the dash and it shows a PO522 which pertains to the oil sender. All plugs that I had to disconnect were marked and hooked back up correctly. I dont know where to go from here. I purchased a Haines manual and it's ok but doesn't show the engine wiring like I wanted [ or haven't found yet]. Any help greatly appreciated as it is driving me totally beserk.
The cam sensor was never unplugged, neither was the coil.
![]() Quote:
![]() Quote:
_________________________________________ '07 2.2 CRD |
They are fine. If that we're the case it wouldn't crank when jumped directly to the solenoid.
Yes ,I understand.I'm grasping at straws also.
Are you sure you got the wires back on the starter correctly? Not trying to piss you off, just asking a question that COULD be the problem if the small wires are in the wrong place.
![]() Aspire to inspire before you expire. |
Thread Tools | |
Display Modes | |
No Start After Timing Belt | mtyson | General PT Cruiser Discussions | 4 | 03 May 2019 04:53 am |
About to start timing belt job! | fisheyestudio | Tech & Performance Forum | 5 | 22 Jul 2016 01:13 pm |
After timing belt wont start | moparman75 | Tech & Performance Forum | 1 | 17 Apr 2011 10:39 am |
timing belt/ no start/ no compression | sylster | General Turbo Discussions | 8 | 01 Mar 2010 08:42 pm |
timing belt no start | YouPutz | Tech & Performance Forum | 17 | 27 Feb 2010 04:38 am |
