Strange issues, need help asap!
  • 1 Post By Ironman
Old 06 May 2020, 07:54 pm
Send a message via MSN to Ironman
Default Strange issues, need help asap!
A few months ago the ignition switch on my 2003 Touring got stuck, it wouldn't allow me to turn the key. I took off the cover and gave the cylinder a smack with a hammer, which fixed it. Yesterday, while cruising down the highway at 75mph with cruise control on, all power in the PT cut off. the spedo ramped down quickly as everything shut off. As I was getting ready to move to the shoulder, it fired back up and continued as if nothing ever happened. Today while shifting between 3rd and OD the transmission apparently shifted into neutral and won't shift out. I checked the fluid level, it's fine, The fluid doesn't smell burnt and looks new. I checked that the shift arm on the transmission moves when the selector is moved. It has about 160K on the clock and is an auto. No codes were thrown in either incident. Help!
EDIT: I forgot to mention, over the past few months it sounds like the fuel pump runs for about 10 seconds after I shut off the PT.
rockandroller likes this.
Non Turbo, Automatic Transmission 2003 Touring Edition, 104,xxx miles so far. Extras- cruise control, fog lights, sun roof, rear defroster, ABS, rear disk brakes, six speaker sound system, power locks, power windows, A.C., window tint, locking glove box. My personal mods so far- removed white air restricter, white hibiscus flowers sticker above the rear hatch lock, nice white primer/rust splotch underneath the passenger side tail light from bodywork...more to come once the money starts flowing freer and the car is payed off
Old 13 May 2020, 08:43 pm
Default Re: Strange issues, need help asap!
Boy is this place dead. On the advice of people from two Facebook groups, I replaced the ignition switch, actuator, and cylinder. No change. I'll be going over connectors and ground wires this weekend if time allows. Next step, test the TIPM.
Old 11 Aug 2020, 12:55 pm
It is. PT not as popular as it once was.
Old 12 Aug 2020, 11:15 am
thecabinguy's Avatar
I do check this forum every once in a while but not as often as before. My interest with the forum had always been for tech services, advice, and information. Sadly so much of this has diminished. Times are a changing, that's for sure.
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Old 12 Aug 2020, 01:37 pm
The 2003 Pt Cruiser does not have the TIPM.
If you are still working on it after 2 months did any codes get triggered?
Old 12 Aug 2020, 06:17 pm
rockandroller's Avatar
"fuel pump runs for about 10 seconds after I shut off the PT." - I have not looked at the schematics but I can't imagine that could be anything other than a computer problem. Sounds like it might be time to give your car a brain transplant!
2004 'Turbo Lite'
Strange timing belt failure and other strange symtoms StephenB Tech & Performance Forum 5 28 Mar 2016 12:57 pm
I need help ASAP!!! ebonylocke Tech & Performance Forum 11 15 Jul 2015 09:30 pm
PT Cruiser high rpms and strange acceleration issues CarNoob85 Tech & Performance Forum 9 28 Jan 2014 09:50 pm
NEED HELP ASAP!!!! myyellowty General PT Cruiser Discussions 5 21 Dec 2008 08:21 am
PLease help asap turbomangt General PT Cruiser Discussions 5 12 Oct 2003 12:00 am
