Front and Rear Calipers replaced
Like Tree4Likes
  • 1 Post By rhino169
  • 1 Post By rockandroller
  • 2 Post By rhino169
Old 04 Jun 2020, 11:31 am
Default Front and Rear Calipers replaced
Well I finally replaced the front calipers and brackets, rear calipers, front rotors and brake pads.
These were the original calipers and the lower booted spring bolt stuck on both front calipers/ brackets and basically disintegrated the inner brake pad.
I had a weird question or not. when I bought the replacement items from the local auto parts store, they mentioned that the rear brakes do all the work.. is this true? they are quite a bit smaller than the front ones.
rockandroller likes this.
388,200 miles as of 6/4/20 '01 PT Cruiser automatic Original (Engine, Transmission, Power Steeering Pump)...3rd Radiator and Fan (with added fan toggle switch mounted inside of car)...3rd Crank Sensor, 2nd Cam Sensor, 3 Timing Belts replaced (1st at 140,000 the 2nd at 345,000 the 3rd at 369,000 due to tensioner fail), 1 Rack and Pinion, 1 water pump at 345,000, 2 alternators - 1 at 345,000 and 1 at 384,000) 4th Watts Link, Serpentine Tensioner at 369,700, New front and rear Brake Calipers at 388,000.
Old 04 Jun 2020, 12:20 pm
rockandroller's Avatar
Smile Re: Front and Rear Calipers replaced
Its just the opposite! the front brakes do all the heavy lifting.
I just had the first full brake rebuild in about 100,000 miles, and (finally) got the new fronts done same as you. (pads/rotors/calipers)
However, they didn't touch the rear brakes, because they are still at 70%!
rhino169 likes this.
2004 'Turbo Lite'
Old 04 Jun 2020, 01:24 pm
Default Re: Front and Rear Calipers replaced
Yes I figured they were of base... I mean the front brakes all around are much beefier!
I hope I can get to 400,000!
FOR SALE - Brand new left and right rear calipers JonN Classifieds: For Sale/Trade 2 21 May 2018 03:56 pm
Rear Calipers GT VNT Turbo Wheels/Suspension/Handling 7 01 Apr 2012 10:50 am
Replaced Front Struts Now Shimmy My02RedRide Tech & Performance Forum 8 02 Sep 2011 04:27 pm
Almost all of the front end needs to be replaced??!! Triplecat2002 Turbo Wheels/Suspension/Handling 5 17 Jun 2010 07:59 pm
Front Brakes - replaced, and now mushy sifu_scott Tech & Performance Forum 9 21 May 2009 09:05 pm
