SOOO BIG question Check engine light on. Test coded P 0340
Like Tree33Likes
  #11 (permalink)
Old 05 Oct 2020, 04:51 pm
dougs's Avatar
Default Re: SOOO BIG question Check engine light on. Test coded P 0340
Hmmmm...
Lately the black PT takes 1/5 - 2 seconds of cranking when I turn the ignition key before it starts. Used to fire up in less than half a second.
Wonder if it could be a tired sensor?
ptprice likes this.
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
  #12 (permalink)
Old 06 Oct 2020, 09:11 am
ptprice's Avatar
Originally Posted by dougs View Post
Hmmmm...
That could be caused by a multitude of problems. Fuel delivery, bad spark plugs, vacuum leak, loose or bad gas filler cap, to name just a few.
Check if the electrical plug is secure on the sensor.
See if you're getting the P 0340 code?
If so, that code points to the cam positioner sensor.
Replacing it with an original equipment Chrysler unit might help.
I've been told to use only the original equipment sensor as the aftermarket sensors, even though they're cheaper, don't always function as well.
Attached is a photo of the sensor showing where it's found on the engine.
I hope that helps you.
rockandroller likes this.
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Tail Lights, 3/8" Belt Trim, 5 piece bumper trim, Leather tilt steering wheel, Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
  #13 (permalink)
Old 06 Oct 2020, 11:35 am
Hmmmm...
I would suggest checking the battery cable contacts. If good have a battery load test done.
ptprice and dougs like this.
  #14 (permalink)
Old 06 Oct 2020, 08:49 pm
dougs's Avatar
Thanks! No codes, not a loose gas cap, no vacuum leaks.... I think I will replace the plugs (last replaced 50,000 miles and six years ago) and put in a new cam sensor. Yes, it will be OEM! I learned my lesson a few years ago when I replaced the engine mounts in my Camry with 'cheap' ones (made in China!) that only lasted two years and 30,000 miles.....
ptprice likes this.
  #15 (permalink)
Old 06 Oct 2020, 08:53 pm
dougs's Avatar
Yep. Did that already. Put a new battery in. thanks!
  #16 (permalink)
Old 07 Oct 2020, 11:33 pm
You might have a battery drain issue. Is it worse if the Pt Cruiser sits for a while?
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
