pcv replacement
Like Tree3Likes
  • 3 Post By FeelthySanchez
Old 29 Nov 2020, 10:29 pm
Default pcv replacement
on replacing the pcv valve on 06 turbo PT is it ecessary to replace anything else like a hose?
Old 15 Dec 2020, 10:16 pm
FeelthySanchez's Avatar
Default Re: pcv replacement
Not per se, & the valve is easily cleaned w/ aerosol solvent.
Does it rattle freely now? If not, maybe try a squirt before tossing it.
But, please be advised that the hose is frequently a bigger problem: it will usually be age-cracked on the PCV end, & LEAK vacuum. The upside is - they're still cheap.
I installed this hose about a decade ago, & the engine ran smoother IMMEDIATELY.
G' luck:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Orig owner 100% stock Patriot Blue 2001 LE 5-spd: 293,177 miles & rolling on it's 3rd ECM, 2nd engine, 4th gearbox, 2nd rack & pinon.
"The idiot's guide to passing yourself off as leadership" - Ed Hipalito. Author, mgmt failure, narcissistic buffoon.
Old 16 Dec 2020, 12:09 pm
Handy_Cruiser's Avatar
Besides that hose that WesternslopePT recommended, you might want to considered adding a check valve between in the intake manifold and the new PVC valve. This seems to help reduce blow-by that is due to turbo boost. The PVC valve alone sometimes has a hard time and may not react fast enough. I like to use the Boomba valves because that is what they are designed for. But there are cheaper ones as well.
New inner tie rod replacement RVC Tech & Performance Forum 4 09 Oct 2017 06:41 pm
2001 PT - Engine mount replacement needed with Oil pan replacement? SanPT Tech & Performance Forum 14 23 Sep 2012 08:49 pm
Oil Pan Replacement - OEM? SteveG22 Tech & Performance Forum 8 21 Oct 2011 01:40 am
Oil Pan replacement??? renee1958 Tech & Performance Forum 12 13 Jan 2009 04:54 pm
