im popin 25lbs of boost
Old 06 Dec 2020, 10:54 pm
Default im popin 25lbs of boost
i changed the internal bov to the blue plate that makes sounds,
and had a new strut put in,
they guy crushed my hoses coming into the 4 solinoids that sit right by the passenger strut tower when he reattached my brace,
i fliped, and pulled it all appart and re secured the hoses and remounted them,
also i put new wires and plugs on,
i keep popin over boost codes, i can hear the bove plate leting off presssure, im not sure whats wrong
i also switched out the map sensor to a new stant one, and i just bought a mopar one to swap it back to mopar as im thinking it might be faulty.
Old 06 Dec 2020, 10:56 pm
Handy_Cruiser's Avatar
Default Re: im popin 25lbs of boost
Those hoses are plastic. Make sure some of them are not still pitches or bent closed. Also, if the hoses were repairs, make sure the are hooked up correctly.
Old 06 Dec 2020, 11:16 pm
is ther a manual digam
Old 07 Dec 2020, 01:01 pm
What boost codes are you triggering?
Loud popin right rear area athenssandy Tech & Performance Forum 4 10 Feb 2014 11:10 am
HP Boost? Ptnovice Tech & Performance Forum 22 09 Sep 2013 08:18 pm
Does the Pt really boost in 4th needmoretoys General Turbo Discussions 24 19 Apr 2013 07:11 am
not enough boost!! jakeiniowa Turbo Performance 17 15 Nov 2011 08:58 pm
Part Throttle boost with boost controller forcedinduction Turbo Performance 2 18 Feb 2006 01:48 pm
