power steering leak
Like Tree4Likes
  • 1 Post By lizardtrack
  • 1 Post By LionPT
Old 26 Dec 2020, 11:20 pm
Default power steering leak
the fitting going into the bottom of the pump is leaking. is there a special O ring that goes on the fitting, if so where do I get one?
Handy_Cruiser likes this.
Old 27 Dec 2020, 10:15 am
Handy_Cruiser's Avatar
Default Re: power steering leak
You have a 2001 PT with several hundred thousand miles on it. Right? And didn't you change out the line, pump and tank about nine years ago?
If me, I would try tightening the fitting first. It may have just became loose. If no joy, take the fitting loose and check the o-ring. If may have deteriorated over time.
Old 27 Dec 2020, 01:23 pm
I Think the O ring is the problem. will any O ring work or is it special? thanks.
Old 27 Dec 2020, 01:45 pm
The correct answer is polyacrylate. It's normally black or red and looks like standard butyl rubber but is much better for power steering and automatic transmission applications.
Parts stored often have some replacement power steering o-rings in the Dorman/"HELP" brand. They are normally in the Red HELP bubble packs out on the floor of the store. There's also often some new ones in a "power steering seal kit" but you end up paying for lots of stuff you don't need. I believe most Advanced Auto stores keep both the HELP bubble pack and the seal kit in stock. Some places like NAPA might have individual o-rings for power steering.
If me, I'd take my old o-ring with me when I went to the parts store.
Old 27 Dec 2020, 11:23 pm
I'll check with napa, thanks for the feedback.
Old 30 Dec 2020, 05:05 pm
I found some online but they are either green or black (bulk) no red. will these work or do they have to be red for high pressure? It sure is a pain to change the O ring.
Old 30 Dec 2020, 11:33 pm
Color doesn't matter. What matters is the type of material they are made out of. If the spec says they are good for power steering and/or automatic transmissions, then you are likely okay.
Old 31 Dec 2020, 02:20 pm
I just found out that there is a recall on it for the PS leaking, any ideas?
Old 31 Dec 2020, 03:09 pm
will nitrile butaiene work?
Old 31 Dec 2020, 03:43 pm
LionPT's Avatar
If it was recalled...take it to the dealer, they'll look up your VIN & if it's never been fixed, they'll fix it for free. If it has been fixed before, you pay.
Power Steering Leak mtyson General PT Cruiser Discussions 6 15 Dec 2018 08:00 pm
Power steering leak oliverav Tech & Performance Forum 12 07 Apr 2013 09:46 pm
Power steering leak brandenfwee Tech & Performance Forum 5 25 Dec 2011 01:50 pm
Power Steering Leak (help) mjb457 Tech & Performance Forum 3 13 Jun 2011 05:46 am
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
