Can I swap engine from different year?
Like Tree5Likes
  #11 (permalink)
Old 08 Jan 2021, 12:05 pm
dougs's Avatar
Default Re: Can I swap engine from different year?
Originally Posted by ptcruisersteve View Post
I would suggest looking into a 2005 engine in a Pt Cruiser with an August 2005 date or earlier manufactured date on the driver's side door.
additional information:
https://www.enginebuildermag.com/200...chrysler-2-4l/
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
  #12 (permalink)
Old 08 Jan 2021, 03:51 pm
Originally Posted by dougs View Post
I see the article was written in March of 2007.
  #13 (permalink)
Old 11 Jan 2021, 12:16 pm
Any reason an early 05 is better than an 04?
  #14 (permalink)
Old 11 Jan 2021, 02:09 pm
You might find one with lower miles.
  #15 (permalink)
Old 12 Jan 2021, 05:19 pm
Should I even consider fixing the head gasket, or head if needed, on an engine with 265,000 miles? Only uses or loses a qt of oil every 1200 miles for the last eight years.
  #16 (permalink)
Old 12 Jan 2021, 08:42 pm
That is a good question. The problem I found with my 2007 Pt Cruiser after putting new valve guides in it is that I got 5000 miles per quart until I had about 8,000 miles on it and then it gradually went back to 1100 miles per quart of oil. My opinion is that the aftermarket CAT from Rockauto gets hotter than the factory CAT and ruins the valve guides. I can only get about 35,000 miles before the aftermarket CAT clogs up. I haven't decided yet if I am going to go with a new Factory CAT on my 2008 Pt Cruiser considering how much more expensive it is. This is my theory so do some homework first. keep in mind I am in California.
  #17 (permalink)
Old 12 Jan 2021, 09:45 pm
Think I'll measure the oil pressure before deciding.
2005 Engine swap with a 2001 PT engine murraymac Tech & Performance Forum 3 22 Jan 2017 06:31 pm
Can I swap a 2001 w/egr engine for a 2002 engine w/o egr? cas0918 General PT Cruiser Discussions 5 15 Feb 2013 11:58 pm
is 2003 engine a unique year regarding interchange ? gtgt_bangbang Tech & Performance Forum 10 19 Jan 2013 06:12 pm
different engine year? pettit5 Tech & Performance Forum 0 09 Nov 2007 11:23 pm
Engine Swap macster Turbo Performance 3 24 Feb 2004 12:01 am
