![]() Quote:
Recommend you verify you have fixed the oil light before doing any other repairs. You want to make sure you have no issues so that you can eliminate the oil light issue if something comes up after another repair is done afterwards.
If at First You Don't Succeed - Try, Try Again Last edited by ptcruisersteve; 23 Jan 2021 at 03:09 pm. |
![]() Quote:
I own a Japanese screw air compressor packed with idiot proofing systems. All my problems are caused from those systems going haywire. I'm slowly reverting it back to 1960 simplicity (reliability). Last edited by circus; 23 Jan 2021 at 11:22 pm. Reason: reliability |
![]() Quote:
If at First You Don't Succeed - Try, Try Again Last edited by ptcruisersteve; 23 Jan 2021 at 11:05 pm. |
Saved a ton of money when buying the, like new, diesel screw compressor from United Rental. They started it but couldn't shut it off. Trying for 30 minutes. Instead of a kill cable there was a linear motor so the fail safe (idiot safe) system could kill the engine. Some electric contacts had corroded and nobody knew how fix it. It's sort of like a modern car with only a 6 page repair manual. Half a dozen idiot lights zero gauges other than air pressure.
What to do, what to do. It's either a new head gasket, engine or car. Fix the known good 263k engine or gamble on a used 100k engine. The car's still good enough for short trips. There's rust, a broken windshield and low car value to consider. Don't need the car.
![]() PS Steve, I did order a new sending unit like you suggested. Driving around with a flimsy test gauge is too risky. Last edited by circus; 26 Jan 2021 at 12:15 pm. |
Well the $6 sending unit came in. Twenty minutes installing it. The oil light works fine. What did I learn? Don't buy from O’Reilly. The black list is getting pretty long.
![]() Quote:
Thanks. |
![]() Quote:
![]() Quote:
Thread Tools | |
Display Modes | |
ABS Light, Parking Brake Light, Traction Control Light | kupothechocobo | General PT Cruiser Discussions | 9 | 28 Feb 2017 01:56 pm |
Showing ABS light, Brake light, Traction light on Dash | fox50h | Tech & Performance Forum | 19 | 18 Feb 2014 11:40 pm |
car won't start, goofy sound | jdmickies | Tech & Performance Forum | 6 | 21 Feb 2010 08:50 pm |
goofy code | jdmickies | Tech & Performance Forum | 5 | 03 Nov 2009 10:46 pm |
Monster PT mods, and other goofy ideas | PTGT-NH | General PT Cruiser Discussions | 2 | 07 Jun 2003 04:02 am |
