EGR to Non EGR head
Old 29 Mar 2021, 07:53 pm
Default EGR to Non EGR head
I looking at putting a non EGR head on my 02 and just leaving the EGR and plumbing attached. Will it throw a code ? Or other issues ?
Old 29 Mar 2021, 08:21 pm
Handy_Cruiser's Avatar
Default Re: EGR to Non EGR head
I don't believe that will work. I believe there is a small difference in the deck of the 2001/2002 EGR engine compared to the later model engines. Additionally, the EGR light will stay on if the EGR is missing. The PCM in the 2001/2002 PT uses the MAP sensor to detect a pressure change in the intake manifold when the EGR is engaged. If there is no pressure change it will throw the EGR light. You cannot easily fix this issue without modifying the programming in the PCM. I know, I've tried eliminating the EGR myself. For you, it's not worth the trouble nor the risk of the head not mating with the block properly. Just get a 2001/2002 head and put it back as it should be.
head gasket? Head ? radiator ?????? rustytoolss General PT Cruiser Discussions 15 12 Sep 2014 12:57 pm
PT Getting New Cylinder Head, Head Gasket, Water Pump. What Could I Mod? 06turbolite Tech & Performance Forum 8 14 May 2013 09:16 am
03 pt turbo oil in water new head gasket fresh head strokedoutss General Turbo Discussions 7 17 Apr 2013 04:22 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
