Radiator/Water Reservoir Issue
Like Tree6Likes
  • 2 Post By Carl48
  • 1 Post By KeMo
  • 1 Post By raeder
  • 1 Post By soonercruiser
Old 23 Apr 2022, 12:27 pm
Default Radiator/Water Reservoir Issue
I'm having issues with my water reservoir pulling water from my radiator and not returning it after the car cools down.
I have a 2005 Cruiser. Just replaced the heater core and the radiator cap. I have an 18 psi cap instead of the 16. I read several posts on this site about going higher on the cap pressure. I have had a radiator pressure test done and it's holding at 16.
This issue I'm having was going on BEFORE I replaced the cap and the heater core.
The car does not overheat after driving around town.
I've included pictures of the reservoir water level and where the water is sitting under the cap.
Is there anyway to fix this?
Old 23 Apr 2022, 02:15 pm
Default Re: Radiator/Water Reservoir Issue
There has to be a vacuum created as the radiator cools down to allow the coolant to return to the radiator from the overflow bottle. if the hose between the two has even a pinhole leak or if the connection at either end of the hose is not tight then no vacuum and thus no coolant return to the radiator.
KeMo and raeder like this.
Old 23 Apr 2022, 04:12 pm
Thank you for the reply!
I went out and started checking around that hose and as I was lifting it up out of the side engine crevice, water started pouring out right where the hose connects to the radiator. I pulled it off, cut about 1/4 of an inch off and reattached it to the radiator. I started the car to get it warmed up, then turned it off to let it cool down and see if it does it's thing. I'll let you know in a few hours how it went.
Cat22 likes this.
Old 23 Apr 2022, 09:43 pm
soonercruiser's Avatar
The other thing that I have noticed on my 7 PTs is, a PT does not like to have the reservoir full.
It will always spit out what it doesn't need.
And that I can barely see the level in the reservoir most of the time.
I overfill - it spits it out!
Frank, aka SOONERCRUISER,
Old 27 Apr 2022, 12:41 am
My buddy is looking at this PT with intermittent overheating issue. The owner replaced the radiator cap and it still overheat. We'll take a look at the hose and pump this weekend after we install the bumper and rack from 4Wheelonline onto the Jeep TJ.
soonercruiser likes this.
Old 27 Apr 2022, 04:05 am
Make sure the cooling fan is working properly.
The water pump is in the engine driven by the timing belt.
Old 27 Apr 2022, 09:40 pm
When it overheats, be sure to check the upper radiator hose!
If it's still cool, he's got a bad thermostat.
raeder likes this.
Old 02 May 2022, 03:11 am
It overheats! We'll check the hose.
Old 04 May 2022, 08:43 am
I apologize for the late reply. I had a million things going on since I last posted.
Here's my update.
After cutting some of the overflow hose off, it seemed like it worked for a day, then when right back to pulling water out of that radiator area (sorry, I'm a computer repair guy I don't know a lot about cars) and sucking the water I added to the radiator into the reservoir. My only option left is to replace that hose.
I'm guessing that it's called an "overflow hose"? Do you know what the size is for the replacement?
I found some on Amazon, but I don't know the size.
This is the one I was looking at: https://www.amazon.com/Length-Temper.../dp/B08LP968ND
Old 04 May 2022, 11:54 am
You should be able to find a suitable size hose at your local auto parts store.
raeder likes this.
2-row aluminum radiator & water inlet jalve Tech & Performance Forum 4 29 Jun 2020 07:38 am
Coolant in Reservoir, Not in Radiator Tube cricket12 Tech & Performance Forum 13 14 Sep 2016 05:45 am
Water bubbling out of coolant reservoir when turning car off ponyboyonair General PT Cruiser Discussions 2 28 Dec 2015 10:40 am
Coolant leak between water pump and bottom radiator house Morgan89 General PT Cruiser Discussions 0 12 Oct 2015 01:38 pm
Timing Belt, water pump and radiator success. DenisMcG Tech & Performance Forum 24 19 Nov 2012 06:27 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
