Oil Pan Gasket Replacement?
Like Tree5Likes
  • 1 Post By soonercruiser
  • 1 Post By Carl48
  • 1 Post By rcalzadilla
Old 21 Jan 2023, 03:47 pm
Send a message via MSN to rcalzadilla Send a message via Yahoo to rcalzadilla
Default Oil Pan Gasket Replacement?
2001 2.4L Automatic.
Have just discovered an engine oil leak at the oil pan rear mating surface so need to replace the pan gasket.
Have searched around the net but curiously find nothing, which makes me wonder whether anyone has replaced this gasket.
Any comments or ideas would be appreciated.
2001 PT 117K Miles Ltd Edition
Old 21 Jan 2023, 07:05 pm
soonercruiser's Avatar
Default Re: Oil Pan Gasket Replacement?
ROCK AUTO has it all!
Here's a link; but I only searched 2004 NA.
https://www.rockauto.com/en/catalog/...an+gasket,5436
rcalzadilla likes this.
Frank, aka SOONERCRUISER,
Old 21 Jan 2023, 07:55 pm
Check O'Reilly and AutoZone.
Appears that the 01-02 gasket is different than later years.
Old 25 Jan 2023, 10:01 am
Just happens that I have ordered from, RockAuto, the oil pan gasket, oil filter adapter gasket, oil pump tube O ring, and installation tool by Fel-Pro, 6mm. Good prices for all items except the installation tool could have saved about $7 at Amazon due to the extra shipping by RockAuto because the item ships from a different warehouse.
soonercruiser likes this.
Old 25 Jan 2023, 04:44 pm
Have you or anyone heard of someone replacing this oil pan gasket?
I can't find anything related to this gasket replacement, anywhere, so
A neighbor who says he is a mechanic looked and believes it is the pan gasket.
I am not 100% confident about the source of the leak.
Old 28 Jan 2023, 09:21 pm
LionPT's Avatar
I bought a gasket a few years ago from RockAuto, my leak ended up being the cam gasket...so I never used it.
I did look into it though, it's not an easy job.
Good Luck
Old 03 Feb 2023, 11:56 am
The engine oil leak has stopped leaking, incredible but true.
It has been 7 days and 13 trips, local and highway, and not a drop.
On the theory that internal engine overpressure pushed out the crankshaft oil seal momentarily, have replaced the PCV valve and verified that the PCV rubber tube was clean. The original valve rattled freely when shaken, so who knows?
Old 03 Feb 2023, 01:55 pm
Assuming you still have oil left in the engine....
Old 04 Feb 2023, 12:53 pm
Excellent question, and fortunately for me, it is at the top mark of the dipstick, as expected after refilling with the oil originally lost.
Solenoid Pack Gasket Replacement Only? rcalzadilla Tech & Performance Forum 3 24 Apr 2017 01:40 pm
Head Gasket Replacement GrapeApe Tech & Performance Forum 29 13 Apr 2015 11:50 am
2.4L Head Gasket Replacement lmarkie74 Tech & Performance Forum 12 13 May 2014 08:21 pm
06 Head Gasket Replacement laynemoore Tech & Performance Forum 3 01 Jul 2012 02:26 pm
oil pan gasket replacement mash35231 Tech & Performance Forum 2 24 Oct 2010 08:06 am
