Oily smell from air vent when idling
Old 29 Jul 2004, 02:31 pm
Default Oily smell from air vent when idling
I have noticed for a time now that when I am at a stop sign and or idling, I detect a smell from the vent. It smell like oil or something with a petrolem base? I have check the engine bay and under carriage for petrolem leaks and haven't found a thing. I have just turned 30k on it.
Old 29 Jul 2004, 10:01 pm
Art,
Your not being ignored...I guess nobody has an answer for you. Did you try switching from outside air to inside air? Does it make a difference? Do you know about the filter that can be put into the vent that draws air from the outside? When others have had smells, it's usually a musty smell from standing water in the air conditioning vents. One solution for bad smells is to spray Fabreeze into all the vents. Worked for some, but you might have to do it every couple of weeks.
Old 29 Jul 2004, 10:45 pm
Antifreeze also has a oily smell!!! Possibly a small leak dripping on exhaust? [:I]
Old 30 Jul 2004, 10:05 am
I hate to admit it, but this happened to me once and it was because after changing the oil & filter I flat forgot to screw the cap into the valve cover (DOH!)
Brian [:0]
\'03 5-speed S2 Dream Cruiser #1582 w/MP Stage 1 & BOV. Plastic Intake Manifold, rear Eibach springs and Supertrapp axle-back exhaust.
Crane 8.5mm FireWires & Champion Copper Plus plugs, K&N drop in filter. Chrome Plastic AMX TTAB pipe.
(Metro Detroit Area)
Old 30 Jul 2004, 11:15 am
It is coming when the fresh air cycles. Yes I have used the Free Breeze spray. As I said I see no leaks of any kind.
Fuel smell with vent on strangelove General Turbo Discussions 3 04 Dec 2006 01:24 am
New Car Smell RAK402 The Detail Shop 3 27 Aug 2004 07:18 am
Idling Question about Stage 1 ??? retroman715 Stage Turbo Kits 8 26 Aug 2004 12:04 pm
air conditioner smell aimee_in_TN General PT Cruiser Discussions 9 17 Jun 2004 11:02 am
Odor from Vent TXWolf General PT Cruiser Discussions 25 03 Oct 2002 12:21 pm
