PT Cruiser Forum Car Videos
Custom Wheels
Plug wires
  #11 (permalink)
Old 05 Aug 2004, 07:22 pm
Jimbo Jimbo is offline
jmack. I never did anything to the headlights. that's how
they came.Oh by the way you are never done.
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
  #12 (permalink)
Old 06 Aug 2004, 02:24 pm
Hooligan Hooligan is offline
[|)] What he said!!!!!
  #13 (permalink)
Old 06 Aug 2004, 08:06 pm
1lowufo 1lowufo is offline
Absolute best price, 'Ultrarev.com' paid 45.68 & 10.22, total to my door,55.90 for #45428 8.5mm
  #14 (permalink)
Old 11 Aug 2004, 02:44 am
Graveone Graveone is offline
Just installed the Magnacore 8.5 wires and the double platinum Champion Plugs 7570s, and I must say that with 33,000 on my 03 N/A, it's running smoother. Especially noticable at idle, no jumping up and down between 800 & 1200 rpm. Good investment.
Graveone.
  #15 (permalink)
Old 12 Aug 2004, 12:00 am
OK, can I ask if anyone can really tell or notice a difference by changing plug wires.? at some point don't we have to give the engineers credit for developing some of the parts already on the car? maybe I'm missing something. little help?
  #16 (permalink)
Old 12 Aug 2004, 07:55 am
The stock wires are fine - when new. They are cheap, and go bad, giving you idle and running roughness. While the wires are good, you won't feel a difference by replacing. Once the wires start to go, replacing them WILL cause you to notice. Replacing with standard wires will cure the miss, too, but by going to better wires, the fix lasts longer. Resistance goes up with time in ignition wires. The stock ones start at a higher resistance than good aftermarket ones - when resistance gets high enough, poor/no spark.
MY OPINION based on my experience.
  #17 (permalink)
Old 12 Aug 2004, 08:55 am
according to the web site for the mega wires, they show 3 different part#'s for the Turbo. (7m 8.5m and 8m) all with different stock numbers. can someone tell me what's up ? gary
  #18 (permalink)
Old 12 Aug 2004, 10:38 am
They have different resistance (Ohms/ft) I suspect. Also, fatter insulation usually lessens chances of spark arcing from wire to block - which I had happen with old stock wires on another car.... Car was running like a dog, I opened the hood one night with it running and saw the spark jumping.
  #19 (permalink)
Old 12 Aug 2004, 12:16 pm
Sci-Fi Sci-Fi is offline
To add to QSD's post, Magnecor offers different "price points" to the consumer. The 7mm is the direct replacement type wires. The 8mm has lower resistence, higher voltage capacity, and a better outer jacket material (500°F service temp) for the same size conductor wire. The 8.5mm (KV85) has even lower resistence, bigger wire conductor, thicker outer jacket for additional heat resistance (100°F more for a 600°F service temp), etc. etc. Can read this (posted a chart):
http://www.ptcruiserlinks.com/forum/...k,plug,wir es
Just to note, the only difference between the "turbo" and N/A Magnecor wires is that in the turbo versions, all the wires have angled connectors to the coil (only 2 for the N/A set), but you can use either set without any problem. The angled coil connector for the longer wires helps you to route/keep the wires away from hot spots or contact. This information was confirmed by an e-mail sent by Magnecor Technical support. Some PT turbo owners have reported that the turbo wires are slightly longer, while others say the wire lengths are the same, and some opted to exchange/use the N/A spec wires. The R-100 10mm wires have the same internal construction as the KV85 and adds another 100°F (700°F service temp) and is considered overkill for street applications.
  #20 (permalink)
Old 22 Aug 2004, 02:35 am
SteelBlueGT SteelBlueGT is offline
As a practical matter, I doubt if you can tell the difference or even measure it in performance terms between the 8.0 and 8.5 wires of any brand. Our runs are very short compared to a V8 engine so resistance is not that big a deal!
vB code is On
Best Spark Plug Wires for 03 Turbo? zzzhuh General Turbo Discussions 10 13 Oct 2005 04:49 pm
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
no-name spark plug wires Probedude Tech & Performance Forum 9 11 Jun 2005 12:13 am
PERFORMANCE PLUG WIRES 4 GT'Z RODRUN Turbo Performance 4 18 Jul 2003 05:15 pm
PERFORMANCE SPARK PLUG WIRES RODRUN Turbo Performance 1 03 Jul 2003 11:20 pm
  Debt Consolidation | Debt Loans | Final Fantasy MP3 | Loans | Homeowner Loans
