Wire Size?
After cutting the wrong wire for the MX-5 mod, I need to reconnect the wires. Problem is I din't have sodder or a gun, plus it's kind of tight in there. What size wire do I get, and what would you use as connecters? Thanks!
They make plastic connectors that are crimped on to either end of the existing wire. I have picked up a Kit with crimping tool at Sears. You MUST use the tool as just using pliers will damage the plastic and will NOT crimp tightly.!! Good Luck[^]
