Maybe MX-5 or slartyblarfast could comment on this.....
Ok, I've bought "3M Throttle Plate and Carb Cleaner" from NAPA for under $4. I followed the instructions from PTDoItYourself, "Throttle body cleaning" With my assistant (wife) holding the gas pedal to the floor, to open the plate, I sprayed and wiped the inside of the throttle body, as best I could. I got some black gook out of there. Is that it? Will the cleaner getting down into the injectors help clean them out? If you paid for a dealer or shop to "clean your injection system" what else would get done? I have occasionally put in STP and Gumout fuel-injector cleaner additives in my tank. I'm now using the K&N "recharger" kit to clean my AirAid cone air filter element. What about that square of foam rubber that sits inside the bottom of the air canister?(this is a 2002 PT) I'm thinking of using the recharger kit to clean and re-oil it. Thanks for any help/advice anyone can give. SRG |
The carbon on the throttle blade is so much the problem as the carbon that builds up on the pintle on the Idle Air control motor. It causes the hard starting,idle hunting and other odd stuff. You have to remove the motor and clean the passage and pintle. Not hard but depends on your mechanical skill. Berrymans B12 is the only stuff I will use to clean it. I've tried others and Berrymans works better than anything I've tried! On severe cases the gunk on the blade can cause problems but that's rare.
I use the 3M throttle plate cleaner.
That doesn't get anywhere near the injectors or top engine & valves. I use either the 3M fuel injection cleaning system or the OTC system and then the Seafoam SF-16 top engine cleaner. OTC for $647 plus chemicals: http://store.autotoolexpress.com/fuelincleank.html 3M for $811 plus chemicals: http://store.autotoolexpress.com/3-mmm8840.html I use both. Each has it's benefits over the other. |
MX and Slarty:
Thanks for your replies, I'm still wondering what exactly do you feel the average PTer should have done, as far as the injection system, and how much should he pay for it? Most of us are not going to buy $600 to $800 worth of chemicals and do it ourselves. SRG |
I had the dealer clean the throttle body once before at 30K and the cold idle improved greatly. But it was $100! Now at 55K, she's rough again.
I have the '01 5-speed and am willing to give it a DIY try. Any photos of the particular areas to pay attention to would be helpful. Also, just like the Turbos have the oil seperator mod, would installing such a device between the PCV and TB be a simple, dependable mod for the NA? |
Is this the same spray that a DCX tech would use today on a PT Cruiser if a customer requested the TB cleaning? I wouldn't have any qualms using it (if it's even still available) if it'll work. I'm not too fond of my neighbors anyway ![]()
Mike 2003 Patriot Blue GT \"R\" Package Autostick K&N drop-in w/both airbox silencers removed Brand \"X\" Turbo-up pipe |
All I ever use is plain old Berrymans B12 in the aerosol can.It's amazing the crud that it will take off.The only place I have to scrub is the pintle on the IAC and the seat for the pintle.All the rest just sprays off.
I've got 14K on my N/A PT. Just had it in a few weeks ago for rough idling. They changed the plugs and wires, and reflashed the computer. The idle is still pretty rough, it usually stays just shy of 1,000 at idle. At start up, it will sometimes fluctuate between 500 and 1,500 RPM. Every great once in a while, the car will just die on me, it's a 5 speed, but when it dies I usually have the clutch in. It's kind of worrysome. What do ya'll think?
| AT Throttle Body in 5 Speed | mvandale | Turbo Performance | 3 | 05 Dec 2006 12:03 am |
| POWERAID Throttle Body Spacer - Works?? | matt87951 | Tech & Performance Forum | 17 | 23 Aug 2006 09:35 pm |
| Throttle body spacer? | 1lowufo | Tech & Performance Forum | 5 | 23 Mar 2005 09:50 pm |
| Airaid Airmax and throttle body spacers | Robster | Tech & Performance Forum | 22 | 22 Jul 2004 08:12 pm |
| Throttle Body Spacer | PT-ERA | Tech & Performance Forum | 19 | 06 Jan 2004 03:06 pm |
