PT Cruiser Forum Car Videos
Custom Wheels
Tapping into turn signal circuit
Old 13 Mar 2003, 01:31 pm
Stephen R. Stephen R. is offline
Default Tapping into turn signal circuit
I need to tap into a couple of circuits:
1. Right & left turn signals
2. Parking light
I'm looking for an easy-to-access interior location, but not under that crazy dash! Also need to know the method of fishing wires from interior to door speakers. Sounds easy to do, but it's not...
Old 18 Mar 2003, 07:50 pm
OurPTGT OurPTGT is offline
didja check PTDIY?
Kevin & Donna's Elec Blue GT
http://www.dreamcruisers.org/index/Page_1x.html
Old 20 Mar 2003, 12:53 am
2sb 2sb is offline
There's probably an easier way, but here's how I fished wires. With door panel off, disconnect existing wires to give yourself some slack. Squish the accordian tube at the door and work it off the door hole. It's basicly like a grommet. Stretch it some to straighten, then run the new wires from inside the door out thru the tube to inside the car. With it straight and stretched, it's fairly easy to fish a wire thru. Then pulling the slack out, squish and reinsert the tube in the door.
Old 21 Mar 2003, 11:15 am
ceaesq ceaesq is offline
In mounting and connecting Muth wide angle signal mirrors on my GT, I routed wires the same as 2sb through the door rubber tube. The turn signal wires can be tapped underneath the door edge trim piece on each side of the car. On the 03 it was a green wire w/brown stripe on the driver's side, and a brown wire w/ red stripe on the passenger side.
Old 21 Mar 2003, 12:47 pm
Thanks for jogging my long-term memory: http://www.ptdoityourself.net/ptmuthguide.html
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  Credit Card | Loans | Loans | Website Design | Co op Advertising
