| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
I just installed Borla Dual Exhaust on my PT. When not in gear and press accelerator engine hesitates as RPM's increase. Any ideas or suggestions would be greatly appreciated.
Crewzin,
Thanks for getting back to me. More specifically, when the car is in park or neutral and press on gas pedal when reach 4000 RPM its like the fuel is shut off. IF hit accelerator several times to rev up engine between 3500 - 4000 rpm same result. Its not like I really checked before, I replaced exhaust so I can't compare.. When I was done installing exhaust and I started it up to listen to exhaust is whne I notice. WHen in gear in driving everything seems fine. I was talking to a friend who said car might have programmed into computer neutral rpm limiter. I am going to hop into a stock PT to check out if rpm is limited. If you have any other idesa, or anyone else has any ideas I greatly would appreciate the response. |
In another forum, it was noted that if you are not in gear (park or neutral), you have just hit the rev limiter. No worries.
Sci-Fi,
THanks for the "Input". |
Exactly; If you increase the rpms too high in nuetral, Chrysler has a "fuel limiter" to keep it from over reving as we are prone to do with the new Duals to sound them off, that we didn't do with the stock system Hah ;o) Ya just can't win anymore, although I hear there is a diff chip, that will by pass that, that isn't recommended for us ;o(
Tex. |
this revlimiting thing ,,,,is it just for the automatics?
or does it do it to the manual transmission too? problems for me is that when i rev up or when changing gears, the revs seem to stick rather than just drop quickly . is this normal? |
With a 5-speed, you can rev to the redline. Mine will go to the 6250 RPM limiter. Sometimes when taking off really fast, gears don't catch like they should, but that's not the same as revving in neutral.
RN See Mephisto ![]() |
2002 Almond Pearl Limited Edition 27K ![]() |
| Idling Hesitation | Ken Swenson | Tech & Performance Forum | 11 | 23 Mar 2007 09:16 am |
| Parking Brake Light upon Acceleration | JohnM | Tech & Performance Forum | 5 | 27 Jan 2006 09:07 am |
| Emission sensor on, engine hesitation | higear4 | General PT Cruiser Discussions | 6 | 25 Jan 2006 07:09 pm |
| Slight hesitation | DMW | General Turbo Discussions | 3 | 03 May 2005 03:36 am |
| Shimmy on initial acceleration | Boomer | Tech & Performance Forum | 8 | 16 Mar 2005 01:43 pm |
