PT Cruiser Forum Car Videos
Custom Wheels
Spark plugs
  #11 (permalink)
Old 05 Mar 2007, 04:34 am
SteelBlueGT SteelBlueGT is offline
quote:Originally posted by quicksilverdon
Welcome, Tom - you should post this in the General Tech and performance forum...
Here's "poop" on plugs:
Spark Plugs
Note: There are other spark plugs, like the Denso PT16VR13 or Iridium ITV16, but those spark plugs require a specially machined socket and custom spark plug wire sets to install/remove and work properly. In other words, the spark plugs were not designed for use in the PT or 2.4L engine. Lose or crack the special spark plug socket and you will not be able to remove the spark plug. Also, platinum spark plugs are NOT recommended for use in turbo engines.
Champion
Copper - stock # 440 - RE14MCC5 (OEM)
Copper - stock # 470 - RE14MCC5 (supercedes/replaces # 440, but some catalogs list same part #)
Copper - RE16MC (supercedes/replaces RE14MCC5 and new Chrysler recommended gap is .040)
Single Platinum - stock # 3032 (one range colder)
Double Platinum - stock # 7440 - RE14PLP5
Double Platinum - stock # 7570 (supercedes/replaces # 7440)
Double Platinum - stock # 7032 (one range colder)
Note: There is a stock # 3570 listed as marine/truck premium plug, but no further information is available.
NGK
Copper - LZTR4A-11 (supercedes/replaces RE14MCC5 and new Chrysler recommended gap is .040)
Copper - stock # 4306 - LZTR5A-13 (one range colder)
Platinum - PLZTR5A-13 (listed for turbo engine, one range colder)
  #12 (permalink)
Old 05 Mar 2007, 01:39 pm
fritz_t_coyote fritz_t_coyote is offline
This list that keeps floating around is a bit out of date.
There are now Iridium plugs that don't require special sockets.
I have been using NGK Iridiums for about 2 years now, the only 'special' tool I needed was a torque wrench that was accurate at the low end of the scale. (Be Very Careful about the alloy heads)
visit http://www.sparkplugs.com for a current what fits your engine
Most Important:
do not get spark plug work done by chrysler dealers
They will overcharge you (of course) but worse:
When replacing the factory plugs, you also have to replace the factory plug wires. In fact the factory WIRES are absolute JUNK, and usually fail before the spark plugs. If you do it yourself, you can buy and install high-quality aftermarket wires (Crane makes a good set, but practially ANYTHING beats the factory wires).
If you take it to a trusted local independant shop, they will get non-factory wires.
If you take it to a Chrysler dealer, they will put in the same Crud Wires that the factory did...
(Of course the advantage of using factory wires is that you don't have to bother with dielectric grease on the plug boots, as you won't be re-using the wires.)
and the most important thing to remember when changeing plugs:
Anti-Seize is your friend.
www.visualizecommonsense.com
  #13 (permalink)
Old 06 Mar 2007, 06:39 pm
rszappa1 rszappa1 is offline
[|)]Just go to NAPA and get a four pack of NGK 4306 and you will be fine...No need to spend a bunch of money on plugs...They either Fire or not....Type of plugs to not increase HP....They either work or not...[xx(]
  #14 (permalink)
Old 06 Mar 2007, 06:50 pm
doug.barber doug.barber is offline
I have been running standard Champion Plugs (440) in my PT for 6 years now. I have 160,000 miles on the car and haven't had a problem with just the standard plug. The car runs like I just bought it.[8)]
  #15 (permalink)
Old 08 Mar 2007, 02:05 pm
Doug if you have not got rid of those nasty factory plug wires run, dont walk, to your suply house and get high performance wires!!
vB code is On
E3 Spark Plugs CREWZIN Tech & Performance Forum 6 11 Dec 2004 01:03 pm
Spark plugs: newbie question Edwin Astacio Tech & Performance Forum 12 01 Nov 2004 12:21 pm
spark plugs ote69 Turbo Performance 24 12 Oct 2004 01:44 pm
ZEX Spark Plugs Jerry Tech & Performance Forum 9 27 May 2004 07:32 pm
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
  Photoforum | Online Loans | Nike Air Force Ones | Shopping 2006 | Loans
