Battery
Old 24 Mar 2003, 06:39 pm
Default Battery
Just got my '02 Limited - how do you get to the battery? Or maybe you don't have to?
Old 24 Mar 2003, 10:39 pm
The battery is under the the two piece air filter. It's maintenance free and hopefully you don't have to "get to the battery" for many years. There are two access points for the negative and positive terminals if you need to jump start the PT. The negative point is a large screw up front by the hood latch (marked with a white sticker) and the positive can be seen on the right side of the air filter covered with a red plastic cap.
Trade your GAMES & MOVIE DVD's at: www.gametradingpost.net
Old 25 Mar 2003, 12:22 am
If you pull straight up and wiggle on the airbox it will pop out of the rubber grommets that hold in place. You have to loosen the clamp and pull the rubber hose that connects the air box to the throttle body. The whole airbox will come right off.. If you decide to take a look under it just make sure you loosen the hose on the airbox side because there is an air temperate sensor in the hose.
Tried a battery search???? gonzomania General PT Cruiser Discussions 7 22 Feb 2007 12:31 pm
battery access Hud Wilson Northwest PT Forum 1 25 Feb 2006 09:17 pm
Battery Corrosion SteelBlueGT General Turbo Discussions 9 19 May 2005 06:47 pm
BATTERY SOURCE NEEDED clevelandmike General PT Cruiser Discussions 3 06 Oct 2004 09:54 am
Volume reduced when battery disconnected tom-t-rifik Sound and Security Forum 0 28 Jun 2004 05:25 pm
