PT Cruiser Forum Car Videos
Car Rims
Torque question for intake manifold on a GT
Old 29 Oct 2004, 01:12 am
crazie.eddie crazie.eddie is offline
Send a message via AIM to crazie.eddie
Default Torque question for intake manifold on a GT
I'm planning to change my plugs this weekend and since I have to remove the intake manifold, I would like to know what to torque the bolts for the intake manifold.
Please, if you don't have an answer, please don't refer me to any other site.
Thank You.
Old 29 Oct 2004, 02:21 am
Ant Ant is offline
You do NOT have to remove the intake with a GT manifold. That is only for the NA PTs.
Ant
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
Old 29 Oct 2004, 02:27 am
Ooops. Yes, you are correct. Actually, I'm also thinking of changing the ignition coils, which is why I need to remove the intake manifold...hence, the torque question. Of course, I'm still waiting on a verdict whether to change the coils or leave them, since I'm hearing both sides saying the stock GT ignition coils should and some say it shouldn't be changed. It's up to me to decide. But in either case, I just want to be prepared to know what to torque the bolts for the intake manifold at.
<b>\'04 PT GT Graphite Metalic w/Autostick: </b> Stage1, BTG Strut Tower Brace, Eibach Anti-Sway Bars, Airaid CAI, Mopar 2.5\" Dual Cat-Back (D: 14.48@93 - A/S: 14.56@90) <i>...more mods at CarDomain or PTCruiserWorld</i>
Old 29 Oct 2004, 03:31 am
budrzgt budrzgt is offline
hi crazie eddie
look at page # 7 in the install instructions for the stage one kit, it says tighten to 250 inch lbs. it also has your sequence for tightening.
hope this help. BUD
http://www.cardomain.com/memberpage/729184/8
Old 29 Oct 2004, 03:33 am
Duh. Shet...Thanks. The answer was in front of me (sort of) all along.
Since I had the '04 GT all I had to do was just the PCM swap and not worry about the injectors & gasket, so I never bothered to really read the rest.
Thanks again.
Old 29 Oct 2004, 04:00 am
Mean Green Mean Green is offline
You are wasting your money on changing your coil. The factory coil is more than adequate. Just get better spark plug wires. Then again, if it will make you feel better and you want to waste your money then get a "performance" coil.[:I]
\'05 Stone White SRT4
\'04 Graphite PT Automatic
vB code is On
question about plastic intake manifold steve smith Turbo Performance 32 22 Mar 2006 11:23 am
Turbo manifold question proxeyed Tech & Performance Forum 6 29 Jan 2005 12:55 am
BTG shock tower brace CHROMEDCRUISER Wheels, Tires, Suspension 15 08 Feb 2004 03:11 am
to torque or not to torque -oil and plugs thinguy Turbo Performance 12 29 Jul 2003 05:10 pm
  Mobile Phone | Nature Photography | Hybrid Car Rental | Car Accident Attorney Los Angeles | Credit Score
