PT Cruiser Forum Car Videos
Car Rims
Crane Firewire Sparkplug wires
  #41 (permalink)
Old 04 Jan 2005, 11:02 pm
rszappa1 rszappa1 is offline
The NGK Iridion Plud number is #2314.
  #42 (permalink)
Old 04 Jan 2005, 11:47 pm
technobear technobear is offline
Just ordered the Crane wires from R&S $45 shipped. Maggie said that i got 1 of the last 2 sets they will have for that price.
Screaming Deamon: MX-5 sais that it isnt worth it the Stock one provides all the spark you need.
I havent hit the archives yet... whats the best gap for the N/A?
2k3 Electric Blue Touring, N/A, K&N dropin, Silencers removed, Snorkle Replacement, BTG Catback Single Tip Exhaust. \"Technogrounding\", Custom Painted interior, 2k1 5 spoke wheels painted black, Next Destination: Hahn Stage 1. (alas! the perils of insufficient funds)
  #43 (permalink)
Old 05 Jan 2005, 03:21 pm
Hooligan Hooligan is offline
I have heard anywhere from .042.-052. .042 seems a little tight to me, I set mine at .049, I have a '02 NA, and haven't had any problems with that seetting. I also replaced wites with Mopar P4876511 Cables. They are the (High Output) special wires. Can't remember the correct term.[xx(]
  #44 (permalink)
Old 05 Jan 2005, 11:57 pm
Mike-in-Orange Mike-in-Orange is offline
Hooligan, I don't think you'd see a huge improvement in the NA by dropping plug gap. I believe (and someone will quickly correct me if I'm wrong) that the turbo cars came with the same plugs as the NA cars, and at the same gap. The nature of the turbo engine (extra heat and, well, boost!) should neccessitate a different plug, but DCX didn't spec different plugs. The turbo really likes the smaller gap and the upgraded wires. I don't recall reading a report from anyone with a turbo who didn't notice an improvement with this change.
As for upgrading wires on the NA, I would think you might a bit of an improvement there as the Cranes and Magnecors are just far, far better than the stock units.
  #45 (permalink)
Old 11 Jan 2005, 07:25 pm
BumperBob BumperBob is offline
[:I]I have a question for ya'll, have you tried this combination? According to this site:
http://www.cruisermotorsports.com/Co...PlugWires.html
With the Crane Firewire wires, and the Screamin Demon Coil set, you should make the gap wider, not narrower, to allow for more spark for a better burn. I've found this combo for $59.95 at:
http://www.howellautomotive.com/Howe...roducts_id=192
Any comments? Is this a safe and desirable combo for a pretty much stock 2003 Ltd Ed automatic? They claim better performance, and better mpg as well. I'm tempted[8)]
  #46 (permalink)
Old 11 Jan 2005, 08:26 pm
purple04 purple04 is offline
my opinion is not to gap up. GM had specs up to .080 on some cars. A year or 2 later, they issued a TSB telling techs to gap them back down. A coil can only supply so much, and a tighter gap produces a fatter, hotter spark. Ever watch motorcycle mania when he's got a welder tip pulling away from the bench? Engineers with more smarts than me have run tests and found that .040-.050 is good for most N/A applications, providing the rest of the ignition system can handle it, and a bit tighter for pressurized applications. Anything bigger will stress the ignition system and computer drivers.
  #47 (permalink)
Old 13 Jan 2005, 09:03 am
GR8FLPT GR8FLPT is offline
quote:Originally posted by Mike-in-Orange
Hey SuGamer, I picked .042 because people were telling me either .045 or .040. Thought I'd split the difference and give .042 a shot! No joke, that's how I arrived at the setting! It's been working great for me, but as you can see from this thread alone .040 to .045 seems to work just fine. I have not tried regapping at the track to see if it makes any difference. I'd say stick with what works for you.
GR8FLPT - Stock gap is .050 but with the added boost of Stage 1 things seem to work better with a tighter gap. It does seem that dropping the gap can help even without Stage 1 on a Turbo, and if I remember correctly DCX has even altered spec to a lower gap starting with the '05 models. This may apply to Turbo engines only, not sure, so please don't quote me on this!
You figure they would mention that in the S1 instructions...
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
  #48 (permalink)
Old 13 Jan 2005, 09:14 am
so... have we settled on the hot setup yet?
type of plug?
amount of gap?
wires?
with or without new coil?
I'm mentally going broke trying to figure all this performance mod stuff in my head... [:0]
I guess I can do the cheapest thing 1st & gap the stock plugs... only if it wasn't -10 outside today...
  #49 (permalink)
Old 13 Jan 2005, 10:35 am
PTurbed PTurbed is offline
type of plug? NGK LZTR4A-11
amount of gap? 0.040
wires? Magnecor
with or without new coil? Stock
This is what I'm running, It may not be the "hottest" set-up, but it has worked & performed great for me. [8D]
Weather here has gotten ugly lately, down to Minus 25 ( Wind Chills to Minus 40) PTurbed doesn't see much outside activity at these temps, But I've been amazed & pleasantly suprised at how well and streetable Stage I & this set-up has been in this kind of weather. [8)]
PTurbed
  #50 (permalink)
Old 13 Jan 2005, 04:59 pm
thanks PTurbed, thats what I'm looking for. Did the NGK's need a special plug socket to install? & was that the 8 or 8.5 mm wires you installed?
BTW, it's not much warmer "down" here. -10 today w/ -27 windchill last report...
vB code is On
Sparkplug wires warsawdaddy Tech & Performance Forum 14 26 Jun 2006 06:08 pm
no-name spark plug wires Probedude Tech & Performance Forum 9 11 Jun 2005 12:13 am
3/25/05 UPDATE - DONE! - New Plugs and Wires NGK BumperBob Tech & Performance Forum 14 31 Mar 2005 01:06 am
Race and Street & Crane wires KingKole02 Tech & Performance Forum 2 19 Apr 2004 02:58 pm
PERFORMANCE PLUG WIRES 4 GT'Z RODRUN Turbo Performance 4 18 Jul 2003 05:15 pm
  Credit Cards | Myspace Images | Secured Loans | Novela historica | Mortgages
