Parking brake light coming on
Old 03 Dec 2004, 05:08 pm
Default Parking brake light coming on
In the last couple days or so, my parking brake light has come on when I do a good hard acceleration. It only comes on for a quick second, and a short chime will sound. I've got 16,500 miles on my 2003. I try not to use the brake really hard, opting for the tansmission to help slow me down as well (5 spd). I did a search and found that it's the brake pads that are wearing out. Is this the case, or could it be a short in the wiring?
Old 03 Dec 2004, 05:58 pm
Yes...pad wear and low fluid level will do that. In my own case, I continued to drive a few more weeks and the warning light stayed on for a progressively longer time. After brake job, all is well.
Old 03 Dec 2004, 10:05 pm
quote:Originally posted by CHROMEDCRUISER
I Is this the case, or could it be a short in the wiring?
Check your brake fluid & add as necessary until you get the brakes done. Probably not a short.
PTurbed
Old 06 Dec 2004, 02:59 pm
Yeah, just low fluid. I would have your brakes inspected. You probably have quite a few miles left on the current pads, this is just an early warning shot over the bow.
There seems to be a wide disparity in the pad life on these cars. I inspect my brakes every time I rotate my tires and at 23,000 miles I have more than half of the pads left. I wonder why some are wearing out so soon? Some people are doing brakes before they ever reach 20,000.
Old 06 Dec 2004, 08:03 pm
Send a message via AIM to bigtommy83
Driving habits or differents pads from different suppliers at different times. Ust like electrical products. They can look the exact same and have the same part number but they can be made by two or more different companies. Depends on who had the lowest bid, but mainly it is driving habits. Like two fotting it or catching the brakes as soon as you can read the warning label on the stop sign.
\'04 GT 5-speed, Brand X, Air Force One Intake, Custom Flowmaster Exhaust (retired), SRT-4 exhaust no resonators, AGP Wastegate, Crusher Kit, Former Chrome Package, Mopar BOV, Custom Sub Box, Mopar Pillar Gauges, Hood Scoop, MBC, Stage 1, Mopar Stage 1 Springs, Hurst STS
Future Plans: Custom Intercooler Sprayer, 2-tone Paint Job
\"Hondas are like cigarettes, everyone cool smokes them\"
Old 06 Dec 2004, 08:09 pm
That's what it was with mine. If you add fluid, when you push the pistons back when you do change pads, the master cylinder may overflow.
I changed pads instead & found the originals had about 1/2 thickness left. I don't regret it - put in Raybestos ceramic pads and NO DUST.
Old 06 Dec 2004, 08:20 pm
quote:[ If you add fluid, when you push the pistons back when you do change pads, the master cylinder may overflow.
This is just part of doing brakes. Just bleed out the extra or use a vacuum pump and take it out of the MC. I don't like to waste anything so I use 'em up before I replace things.
Old 06 Dec 2004, 09:57 pm
[quote]quote:Originally posted by quicksilverdon
In my own case,
I changed mine at 28K to NAPA ceramics, had over 1/2 pad left. Once changed, NO DUST, just like they day.
Old 06 Dec 2004, 10:11 pm
Hey guys. If you have a PT with ABS, the service manual states not to push the brake fluid back into the master cylinder. You're supposed to add alittle fluid first, then open the bleeder screw so the extra fluid in the piston can come out while you push the piston back into the caliper. Do that on both sides of the brakes you are changing (ie., fronts or rears) then top off the brake fluid when then job is done.
parking brake light going on??? yobiebs Tech & Performance Forum 8 01 Nov 2007 09:25 am
Parking Brake Light upon Acceleration JohnM Tech & Performance Forum 5 27 Jan 2006 09:07 am
Parking Brake Light comes on when shifting patbluecruiser Tech & Performance Forum 6 17 Dec 2004 07:33 pm
Brake Light Warning and chime sound. GTinAZ General PT Cruiser Discussions 14 14 Dec 2004 09:33 am
Brake light indicator coming on cheeseball Tech & Performance Forum 1 10 Apr 2003 01:44 pm
