Parking Brake Light comes on when shifting
Old 15 Dec 2004, 03:28 pm
Default Parking Brake Light comes on when shifting
2003 PT Cruiser 5-speed, NA 30,000 miles
For the last month or so, when I shift, usually 1-2, the parking brake light will come on and beep as couple of times. It does not happen all the time. I know if you are moving and pull the e-brake, the light will come on a beep.
Anyone have this problem. I do not drive the car all the time, its my wife's car. Could I not be letting the clutch out all the way? It just started doing it.
Thanks-
Andy
Old 15 Dec 2004, 03:47 pm
Have you looked at the brake fluid level in the master cylinder? If it's low (due to normal wear on the brake pads) it will cause that to happen when you accelerate. The brake fluid sloshes around and the sensor is tripped until it settles down. If you top off the fluid it stops the problem.
If you have that problem check the brake pads for wear. Mine were only half worn when it happened to me at 35,000 miles, but better safe than sorry.
Black 03 PT Turbo & Black 94 Impala SS
Old 16 Dec 2004, 02:02 am
Brake fluid level is the answer. Have your brake pads checked before you just add fluid. The brake fuild sensors in the PT are very sensitive and you probably have pads left. If so, just add about 1/3 the amount of fluid it takes to fill the reservoir. Your problem will go away until the brake pads wear down more.
Old 16 Dec 2004, 11:31 am
Thanks guys...I will check the brake fluid. I put on my snow tires a couple of weeks again and the pads are fine. I will probably replace them this summer.
Thanks,
Andy
2003 Patriot Blue PT Cruiser
2005 Show Schedule
Cruisers @ Daytona IV - May 6,7,8
Cruise the Alley IV - May 20, 21
Meet Me in St. Louis on Route 66 - July 22-24
Many local shows!
Old 17 Dec 2004, 11:45 am
Agree it's the brake fluid. My pads were about 1/2 gone when the light/chime arived.
Suggestion - change pads anyway and put ceramic pads in - Raybestos is what I used, I hear NAPA sells the same ones - get pure ceramic, not a blend.
The ceramics last and last, but most of all, NO DUST! The new pads will push the fluid level back up. Changed my pads to ceramic at maybe 30,000 miles, now have 80,000 miles, lite/chime never came back.
Old 17 Dec 2004, 07:03 pm
Send a message via AIM to sakigt
lol. Were all having this problem at the same time...although I knew what it was because it happened in my escort.
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 17 Dec 2004, 07:33 pm
I'm having about the same problem, except that when I hit the gas the brake light will come on. On my last oil change (about 500 miles ago) I had the mechanic look at the pads, rotors, lines, and check the fluid. All the pads and rotors were fine, the lines were tight, and the fluids were where they should be. Is there another problem I need to check on?
parking brake light going on??? yobiebs Tech & Performance Forum 8 01 Nov 2007 09:25 am
Parking Brake Light upon Acceleration JohnM Tech & Performance Forum 5 27 Jan 2006 09:07 am
brake light /chime comes on when foot is in fan pppt03turbo General Turbo Discussions 3 14 Nov 2005 10:41 am
Brake Light Warning and chime sound. GTinAZ General PT Cruiser Discussions 14 14 Dec 2004 09:33 am
Parking brake light coming on CHROMEDCRUISER Tech & Performance Forum 8 06 Dec 2004 10:11 pm
