Ignition Questions....need help. spark plugs
Old 09 Apr 2003, 09:25 pm
Send a message via AIM to ptcruzin42
Default Ignition Questions....need help. spark plugs
Hey there all. I have a 2003 PT Turbo. I had a cracked spark plug which caused my car to really mess up and I am looking to upgrade my ignition cables and plugs so as to avoid this problem again. What I need to know is what are the best Spark Plugs I can buy for a turbo engine and what are the best kind of ignition cables I can buy for a turbo engine? I was thinking of getting ZEX performance triple contact spark plugs and magnecor 10mm racing ignition cables. Does this sound good?
"I live my life a quarter mile at a time...for those 10 seconds or less...I'm free"
Old 12 Apr 2003, 02:38 pm
Not sure about the spark plugs (you better double check if the reach is ok, I believe the pt spark plugs are longer), but I have Magnacore's R-100 10mm wires and am happy with them.
It's nice to be important, but it's more important to be nice.
Old 05 May 2003, 10:48 pm
Send a message via AIM to Steve03GT
Try NGK; I use them on my S/C'd Vette along w/ several other Vette guys.
\'03 GT Cruiser,White w/ Auto Stick, MOPAR Stg. I, AirAid intake,Alpine XM radio w/ 4 MBQuartz, Autometer Lunar Boost and A/F Gauges
\'02 Corvette (510 RWHP/510 TQ)
Member of 11sec. club &
NRA Benefactor Member
Old 15 Mar 2004, 03:54 pm
ptcrusin42, what did you end up getting? I am thinking about getting a new ignition coil with the nology wires and zex plugs. But the nology wires are really expensive.
02\' Patriot Blue Cruiser, dual cat back exhaust, blue under car lights, airaid cold air intake, throttle body spacer and custom sound system.*Xenon front bumper (crusher), polished aluminum gas door.
Old 15 Mar 2004, 04:01 pm
I'm using the R-100 10 mm Magnecor wires, and a screamin Demon coil. I am running the Champion #3032 (single Platinum) 1 heat range colder than stock (Plug# RE10PMC5). I have pulled the plugs afer about 7000 miles and they still look and work great. They are gapped@ .042 and I run 2 stage boost, stage 1 10lbs max, Stage 2 15lbs max. Have not had a single ignition issue since I went to that setup and the car runs like a bat out of hell........
Old 15 Mar 2004, 08:39 pm
Cruizn42,
I'm not sure if the ZEX plugs would work for your application. I have them in my 2001 with the ZEX NOS system but they are a colder plug and thry're intention is to help stop detonation when the NOS is added. Hope this helps.
Jerry
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
E3 Spark Plugs CREWZIN Tech & Performance Forum 6 11 Dec 2004 01:03 pm
Spark plugs: newbie question Edwin Astacio Tech & Performance Forum 12 01 Nov 2004 12:21 pm
ZEX Spark Plugs Jerry Tech & Performance Forum 9 27 May 2004 07:32 pm
Spark Plugs kidturbofan Turbo Performance 2 08 Oct 2003 10:40 pm
