| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
When installing the add on fog lamp kit that chrysler sells you may encounter the problem that the turnsignals or hazard lights don't work anymore once installing the new switch. The reason for this is that chrysler is being tight and won't include a $1.00 relay on the new switch. It wouldn't be so bad if they told you to remove it from the old switch and put it on the new one, but, they don't. I luckily, through experience, figured it out before returning the unit several times.
So, when installing the new switch make sure and swap out the turn signal relay from the old switch to the new one. It is located in the middle of the turn signal switch and is about 1" square. It just pulls out and plugs in, 10 seconds work of work but hours worth of frustration if you don't know about it. |
Priceless tip. Thanks! [?]
See Kevin's 2003 Elec Blue GT here: http://www.cardomain.com/ride/477590/1 |
I had that very same problem when I installed mine. After getting the 2nd Multifunction Switch, and it still wouldn't work, I decided to compare the backs of both the new and old (w/o fog lamp switch) and noticed the relay. I have NEVER seen the relay except in/on/near the fuse block.
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
| Reply from Chrysler about Transmission problems | umaxman | Tech & Performance Forum | 5 | 11 Oct 2006 06:17 pm |
| Anyone have problems with Headlights? | Ginger | Tech & Performance Forum | 8 | 01 Jun 2005 07:11 pm |
| So much problems before inspection | Ctown | General PT Cruiser Discussions | 3 | 12 Apr 2005 07:45 pm |
| what problems have you had?? | bobs turbo pt | General Turbo Discussions | 32 | 25 Oct 2004 12:04 am |
| Problems | Oddcouple | General PT Cruiser Discussions | 1 | 17 Nov 2002 01:58 pm |
