dicept1,sorry don't know much about batteries
Just want to tell you I think your Cruiser really looks sharp.[?]
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
There is an optima battery that should fit, the 51R it is 9.25 x 5.0 x 9.0 (LxWxH)
What is the measurement on the stock battery? I measured the inside of the battery tray and i had 9.75"x6.75"x??.? I just don't remember the height, it should clear just fine, no cutting or anything. There are more batteries here: http://www.1st-optima-batteries.com/ |
Only problem I see is that the yellow top batteries sacrafice a lot of CCA for their deep charging abilities. Would that be a problem??
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
The downside of starting batteries is that they will not last very long if you really drain them down very often such as the way proxeyed is using his. They were never designed to be used that way. That is the role of a deep cycle battery. The physical difference is the thickness of the plates inside the battery. The thin plates in a starting battery give off a higher current for a short duration while the thick plates isn a deep cycle battery will withstand lower current draws for an extended period of time without damage. The optimal solution would be to drive the stereo and neons off a separate large deep cycle battery. The two issues would be 1) the extra space for the second (or second and third battery) and 2) getting an alternator large enough to recharge multiple batteries without frying itself.
2003 Almond GT AutoStick, body colored rear splash guards and hood struts, chrome gear shift, AC & vent knobs, billet steering wheel spokes and pedals, AMX1397 Turbo-Intake Pipe. |
I agree with Michael, and would add the wiring from the alternator upgrade. You can't just put a bigger alt. in without looking at the entire charging system. The stock harness uses 6 gauge wire and a fusible link. In fact, since the PCM regulates the charging system, I'd carefully check that, too. Swapping in a 180-amp unit may be too much for the stock PCM drivers. Stock is 120-amp, according to 2001 manual. There are specialty 16-volt batterys for racing, 12-volt batterys with separate terminals for 6-volt cars (12 volts to starter only) and others. If you are running accessories with engine off, I'd look for a special set-up to deal with your situation.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
here is a link. It's old, but physics don't change.
http://www.termpro.com/articles/electsys.html
Another FYI...
When I had corrosion problems with my factory battery, I researched online here and other forums got a little confused about what battery to get. I did my own measurements and decided on thee Optima Battery, the 34R Red Top. There is no 34R for the yellow top. The size of the 34/34R battery is perfect. Some people mention grinding or whatever to the battery holder. If you use the 34R there is no grinding whatsoever. Measure for yourself. 51/51R is too tall!! I used a flathead screwdriver to move the lip over so battery could fit all the way... I mean a totally snug fit. I also replaced the cable terminals with normal ones from Autozone... much sturdier if you ask me. Mine were corroded and broke off when I tried to clean them. |
![]() Pics- http://bumperbob1.ifastnet.com/blingbling.html Mods -http://bumperbob1.ifastnet.com/pt.html GLOW - http://bumperbob1.ifastnet.com/glow3.html \'03 Ltd Ed Light Almond Automatic Chrome Accessories - Grill Kit 1940\'s Fender Kit Hood Port Hole Kit 3 1/2\" Chromed Exhaust Tip Billet Rally Door Pulls Gauge Eyebrows Barbed Wire Look License Plate Holders Chrome PT Logo Valve Stem Caps Modified Stock Air Box K&N High Performance Drop-in Filter NGK Iridium IX Spark Plugs NGK 9mm High Performance Spark Plug Wires TYC Altezza Euro Look Back-up Lights Altezza Euro Look Tail Lights Rear side panel and hatch pinstripe decals Green LED underbody lights |
Optima - rocks. I have the yellow top and three tv screens to boot and can watch a whole move on all three on just the batt and she still cranks.
| Tried a battery search???? | gonzomania | General PT Cruiser Discussions | 7 | 22 Feb 2007 12:31 pm |
| battery access | Hud Wilson | Northwest PT Forum | 1 | 25 Feb 2006 09:17 pm |
| battery | onyx pt | Turbo Performance | 2 | 21 Jul 2005 07:18 am |
| Battery Corrosion | SteelBlueGT | General Turbo Discussions | 9 | 19 May 2005 06:47 pm |
| BATTERY SOURCE NEEDED | clevelandmike | General PT Cruiser Discussions | 3 | 06 Oct 2004 09:54 am |
