'05 sway bar folly
Old 18 Feb 2005, 10:07 pm
Default '05 sway bar folly
This may be old news to some, but Chrysler is randomly omitting the threaded nuts embedded in the rear axle that secure the sway bar cushions. It looks like some wizardry will need to happen to position and spot weld the nuts in place--but it looks possible. If anyone has already dealt with this issue, please post your fix.
Old 19 Feb 2005, 04:48 pm
You don't have to weld anything in place if you are referring to the place that the clamshell that holds the bushing and bolts to the axle. You have to hold the nut in place, start the bolt and tighten it down. It is a PITA but can be done, especially if you have air tools. It makes it easier to just zip it tight once you get it started.
Old 19 Feb 2005, 10:15 pm
zoned,
sorry to hear that you are one of the unlucky ones. I would take it to the dealership and insist they weld in the nuts. Mine were there on my 05 convertible making the rear sway a snap to put in. Otherwise you'll have to find the right ones that fit cause I'm not sure DC even sells the proper nuts anymore. They weren't even listed in the parts computer at my dealership when I purchased the factory install parts (dog bones, bolts, clam shells)
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
Sway bar quicksilverdon Wheels, Tires, Suspension 8 04 Feb 2005 08:47 am
Installed Eibach Anti Roll Kit(Front & Rear Sway) Gear_Head Turbo Wheels/Suspension/Handling 27 28 May 2004 02:05 am
Replace/install both sway bars or just rear? im4gzs Turbo Wheels/Suspension/Handling 11 23 Feb 2004 09:11 am
where to get sway bar set for the best price? or.. PtPaully Wheels, Tires, Suspension 11 12 Dec 2003 01:53 am
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
