Matt,
All that is, is the original cover on the OEM air filter box which I painted and cut the sides off. I couldn't use the whle box as I had the aftermarket filter. That striped cover just sat on top of the battery to cover it up during shows. It would come/fall right off if the car was moved as it's not fitted/tied/glued down at all. There's all kinds of aftermarket dealers selling battery covers. Here's a couple of them for you: http://www.gotmypt.com/html/battery.html http://www.fastlanegrafix.com/Batterycovers.html
Got mine from second vendor on above list and I like it! When I first looked into covers they were like $100 so these new ones while not much to them they do look nice in the engine compartment and cover that ugly battery!
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
Gonzomania,
You are trying to use the Volant intake on a 2002 1/2 and up PT. The kit was meant to be used on 2001 and some 2002 PTs that had the PCV line that emptied into the rubber intake tube after the stock filter box. You need to make sure that one of the two holes on the Volant intake tube is plugged (the lower hole that is out of sight). The PCV line can be capped with a small gauze filter (K&N type) like those used for breathers. Depending on where you live and the local emissions laws, this may be an acceptable route. If not, you could extend the PCV line to the aforementioned plugged hole to tie the PCV line into the intake system and remain "emissions legal." However, I would highly recommend a catch can (a simple portable air compressor water separator will suffice) to catch the oil vapor before it enters the throttle body. BTW, did you get the kit from "02Cruizer?" Scott
\"If you choose not to decide, you still have made a choice.\" |
Gonzo,
Did the hose plug somewhere into the air filter housing or tube running into the throttle body before you took the OEM filter out? If it did, there's no reason not to run it into the plugged hole of the Volant filter. I think the turbos are the only ones seeing the oil in the air box so I wouldn't worry about it getting into your TB.
gonzomania,
Send me a PM. Scott
==Fritz (who doesn't understand this trend to covering the working parts under the hood)
I just tell anyone who asks that "PT" stands for "Plymouth's Tombstone" --- Defend Our Hobby! Join the SEMA Action Network http://www.semasan.com |
| Volant cold air intake for sale/non turbo | 03tangerine | Classifieds: For Sale/Trade | 3 | 27 Jan 2005 07:27 pm |
| 3" cold air or 2 1/2 " hot air intake ?????? | amx1397 | General Turbo Discussions | 12 | 25 Jan 2004 12:35 pm |
| Cold Air Intake | Mean Green | Turbo Performance | 8 | 10 Oct 2003 03:57 am |
| Real cold air intake | Airbillster | Tech & Performance Forum | 5 | 02 Sep 2003 02:26 am |
| A TRUE cold air intake | Airbillster | Turbo Performance | 7 | 14 Aug 2003 01:19 pm |
