electronic problem ASAP HELP!!!
Old 17 Apr 2003, 09:01 pm
Send a message via AIM to ptcruzin42
Default electronic problem ASAP HELP!!!
I was installing a cd player and forgot to cap an extra 12v constant that came on the harness. Well it slapped against the metal chasis inside the cd player opening and sparked and after this my lights in the car went out. I checked the fuse box and no fuses are blown, I checked the relay box under the hood, no blown fuses. My interior lights won't come on, my keyless entry doesn't work, my cd player won't turn on, and my power mirrors won't operate. Does ANYONE have ANY clue what the problem is? I don't think the wire is fried because it has power at the fuse box, the wire that run from the fuse box to the cd player, fuse box to interior lights, and fuse box to mirrors, has power. Does anyone know if there is a fuse somewhere else or a circuit breaker or something I can trip? PLEASE respond ASAP
"I live my life a quarter mile at a time...for those 10 seconds or less...I'm free"
Old 18 Apr 2003, 03:47 am
Send a message via AIM to GTcamster
ive had fuse's blow on me in wired spots, maybe try replacing all the effected systems any how under the hood and dash. it might be a relay too...
cheep place to start.
or pull the power off for 5 mins and let the pcm reset, thats just a dumb idea tho.
Deep Cranberry Pearl Coat GT ~ 5 speed
Old 18 Apr 2003, 07:18 am
Sure sounds like a fuse or relay to me. Sometimes it's not easy to see the burnt out fuse. The owners manual will tell you which fuses to look for and as GTcamster said, replace the effected fuse anyway because I've seen them burn out near the edge rather than the middle.
Old 18 Apr 2003, 06:48 pm
I found it, it was the crappy little plastic lift fuse under the hood. Fuse #18.
Old 18 Apr 2003, 09:14 pm
Hi ptcruzin42,
Did you get your GT at Rick Keffer in Yulee? I am up here in Brunswick, GA; and bought down in Florida to get the GAP insurance.
2003 Onyx Green PT-GT
K&N Drop-In Air Filter
Kenwood Sirius Satellite Radio System
Garmin Street Pilot III Color GPS
Old 18 Apr 2003, 10:28 pm
Yep, that's where I got it. :-)
Old 19 Apr 2003, 07:42 am
I have to take my 5 speed back there next week for the Clutch Recall. They said to leave it overnight, because it is the "first one that they have had in for the recall", and it may take some extra time.
So, if you know anyone with 5 speed that will need the recall in that area, I am playing Capt'n Kirk on this one: "Going where no man has ever gone before".
To say the least, I am a little concerned. Have you had any experiences with their Service Department?
I will get my first oil change at the same time, and make the switch to synthetic oil. I think they use Mobil1.
Old 19 Apr 2003, 07:37 pm
I've left my car with them before. They have an extremely friendly service dept. Try to deal with a heavy set fellow named David. Good luck.
Running out of patience with CEL problem coolvirus General Turbo Discussions 5 19 Mar 2007 10:42 am
ARRG!! Odd problem and loose sensor Jason_L General Turbo Discussions 4 18 Mar 2006 01:40 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
Sqealing problem in 2003 PT Cruiser labradorlover Tech & Performance Forum 21 31 Dec 2003 03:44 pm
