My Game Plan for my GT:
BRAKE LINES RUSSELL From ecutuning.com STAINLESS STEEL 694010 $139.00 4 LINES. ROTORS, FRONT & REAR From RACECONCEPTS SLOTTED, DRILLED ZINC WASHED, $159.00 Complete Set 4 Rotors PADS, FRONT EBC GREEN From AUTOPARTSWAREHOUSE DP21357 $58.00 Set PADS, REAR EBC GREEN From THE TIRE RACK DP21066 $47.00 Set Estimated Cost $403. Is this overkill or just a very good complete brake job for spirited street driving?
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
![]() Yea - I would assume he is replacing the ~12inch section of rubber brake line that attaches between the caliper, and the hard brake lines. How hard would it be to bleed out all 4 corners after switching the lines? I worked on my buddies brakes, and needed to replace a bad caliper, and bleeding that one side was real easy - but how tough is it to do all 4? Or do you only bleed one at a time? Matt
2006 PT Cruiser Convertible GT 1987 Porsche 944 Turbo Past Mopars: 2006 PT Cruiser Convertible 2001 PT Cruiser Limited Edition 1993 Plymouth Sundance/Duster 3.0 litre |
[quote How hard would it be to bleed out all 4 corners after switching the lines? I worked on my buddies brakes, and needed to replace a bad caliper, and bleeding that one side was real easy - but how tough is it to do all 4? Or do you only bleed one at a time?
Matt [/quote] Start with the caliper farthest from the master cylinder (pass side rear). replace that one first then bleed it making sure that the fluid level in the reservior does not run low and allows air to get in the line. Then the other rear, then pass side front, then driver front. Brake lines are kind of a messy job but if you work quickly you don't really loose too much fluid. Keep checking the reservoir though. If you get air into the lines, you start over.
Greg Gavencky The New Jersey Cruisers www.njcruisers.com |
Recently upgraded my brakes w/ Powerslots-Cyro, Russell Steel brake lines and Satisfied carbon ceramic and ceramic pads.She really stops now and I can go much farther into a corner before braking than before. On a recent run to the shore, I had to slow rapidly from 85mph to 60mph. Braking as I had in the past, I ended up quit short of my mark. The brakes are really firm and sure.Alittle costly, but well worth the added safety.
03PTGT: S1,K&N FIPK, BTG Cat-back/cat-sync,Koni's, Eibach F&R sways,Eibach pro-kit springs,Conti extreme contact 215/50/17.NO EMBLEMS |
| Close call with the brakes | sawdust123 | General Turbo Discussions | 7 | 22 Oct 2005 01:13 pm |
| Brakes, stalling, gas mileage, maintenance | emr131 | General Turbo Discussions | 13 | 12 May 2005 01:08 pm |
| Brakes Squeak | Konkeler | Tech & Performance Forum | 5 | 01 Jun 2004 12:40 am |
| Brakes - Turbo vs GT | quicksilverdon | General Turbo Discussions | 11 | 16 Mar 2004 10:40 am |
| Brakes | Artemis | Tech & Performance Forum | 6 | 14 Jan 2003 11:04 am |
