Transmission Downshift harsh
Old 21 Apr 2003, 10:15 pm
Default Transmission Downshift harsh
Hi,
I was just wondering if it is normal for the downshift from second to first on an automatic tranny is rough on other PT's? I can feel the transmission downshift right as I am coming to a stop. Doesn't happen on every stop but does happen alot. Is this normal? I don't remember it doing that before as often as it does now. I read somewhere that they might need to zap the computer and reprogram it. Anyonw had this problem? Is it a problem? Any help would be appreciated.
Thanks
Old 22 Apr 2003, 09:44 am
I have an 01 automatic and don't feel any ruff downshift into first before coming to a stop. About your reprogramming; that's done by the dealer on very early 01's. Anything built after about 8-00 doesn't need the dealer reprogram. What you can do is take the negative or positive battery cable off for a few minutes then re-attach it and go for a drive. it may stumble a bit at first while the computer re-learns the setting and of course you'll lose your pre-set radio stations. Once the car smooths out, drive normally with a little spiritied driving also. The computer will learn the proper settings and pick up new settings for any aftermarket mods you've added.
Old 15 May 2003, 02:58 am
Send a message via AIM to BC4BigMac
We have three Chrysler's with the 41TE automatic transmission and they all downshift rather harshly from second to first. Even our 2000 Town & Country van with the 3.3 engine does the same. Sometimes you don't feel it but you can most of the time. We've learned to live with it over time. Good luck.
03 Electric Blue PT Autostick
Old 15 May 2003, 09:41 am
bcme136's Avatar
http://www.ptcruiserclub.org/cgi-loc...=unread#unread
Old 23 May 2003, 09:23 pm
Agreed with the previous note ... our Cruiser will occasionally (sp?) throw a harsh downshif fron 2 to 1, especially if braking on an uphill to a stop. Our brand new 2003 Caravan does ecactly the same thing.
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 22 11 Apr 2011 03:42 pm
Transmission downshift problem Floyd Harris Tech & Performance Forum 5 05 Jul 2006 07:18 am
Transmission Went Mean Green General PT Cruiser Discussions 8 16 Oct 2004 11:49 am
Transmission fliud - B&M Trick Shift or not? snakepitt1 Tech & Performance Forum 8 22 May 2004 06:58 pm
"Internal Transmission Problem" ??? yobiebs General Turbo Discussions 18 21 Oct 2003 11:17 pm
