OBD engine codes
Old 22 May 2005, 05:52 pm
Default OBD engine codes
My check light came on suddenly yesterday and wanted to know what the code might mean and is it something I can take care. I have a '03 Turbo with an autostick, has 30,000 on the odometer. The code that comes up is: p 0442. I know it has to do with the evaporative system and it indicates a small leak. Any ideas and or suggestions. Thanks! Mike
Old 23 May 2005, 11:17 am
unless you have the proper info and tools, I'd suggest taking it to someone knows what to do. In this case, pressurizing the system to check for leaks is delicate. More than 3-5 PSI will damage sensors.
Old 23 May 2005, 05:32 pm
Send a message via AIM to satellite66
Purple 04 that is a very attractive garage.
2003 Electric Blue 5spd
Many on the political left are so entranced by the beauty of their vision that they cannot see the ugly reality they are creating in the real world.
Old 23 May 2005, 10:26 pm
99% of everyone has said it has to do with probably the gas cap. It is a minor problem and pressurizing the system would not be the brightest thing. I have a factory one coming tomorrow since I had replaced the locking cap a few weeks ago. We'll see what happens. Mike
Old 24 May 2005, 02:00 am
P0442
When monitored: Immediately after a cold start, with battery/ambient temperature between 40F and 90F, and coolant temp within 10F of battery/ambient, and fuel level between 15% and 85%.
Set condition: If there is a leak larger than .040" and smaller than .080" in the EVAP system.
Possible causes: actual leak in the EVAP system, intermittent leak detection pump monitor failure, loose gas cap.
[image]http://img.photobucket.com/albums/v218/Jammers99/kroozah1a.jpg[/image]
<b>Kroozin' the Bay Area since January 14th 2001</b>
<b>www.ptcsv.com PT Cruisers of Silicon Valley Homepage</b>
<b>http://p220.ezboard.com/bptcruisersofsiliconvalley - Club Bulletin Board</b>
<b>Kroozah@comcast.net</b>
Old 25 May 2005, 11:55 pm
Wanted to let you know that I picked up my factory gas cap and put it on and started the engine and NO check light. It is strange that something so benign could be a problem. Thanks for all the help, Mike
Old 26 May 2005, 08:46 am
Yeah, but aren't cheap, easy problems great??
Old 27 May 2005, 12:32 am
Cap was $11.83, pretty cheap to solve a problem. I know dealers are usually very high on parts. I was quite surprise at the price. Mike
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine Light Codes Rob in tx Tech & Performance Forum 2 06 Mar 2005 03:55 pm
Engine codes Kroozah Tech & Performance Forum 8 31 Jan 2005 01:22 am
Check engine light on - & NO CODES?!?! CraigO Turbo Performance 9 20 Dec 2003 02:42 am
