Only 24000 miles with a shimmy
Old 24 May 2005, 02:58 pm
Default Only 24000 miles with a shimmy
Anyboody with a shimmy,My 2003 GT has only 24000 miles and around 35 mph.if I hold the steering wheel lightly some time it shimmys for a long time, Also I have a clunk in the front end,It only does once and a while,Sometimes just as the car comes to a stop or when pulling out or just moving the steering wheel,it doesn't do it often...But I try to make the clunk it won't....I want it to do it so I can take it in...Bob Renninger[:I][:I][:I][:I]
Old 24 May 2005, 03:40 pm
Did you just have tires rotated? The Good-for-a-years are notorious for vibration. If you did, put them back & see. Could also be related to the clunk - check suspension bushings, but I haven't heard of them causing shimmy - you might just be lucky....[:0]
Old 24 May 2005, 08:14 pm
THE last time I rotated was 5000 miles ago,does not shimmy higher then 50 mph.Feels just like my 1936 Ford with bad kingpins,but the play in the steering wheel,Thanks for your help...Bob Renninger
Old 24 May 2005, 08:19 pm
Sorry typing mistake....PT. HAS NO PLAY IN STEERING WHEEL..BOB RENNINGER
Old 24 May 2005, 11:01 pm
Check the lower control arm bushings for separation.
I replace a lot of them for similar complaints.
Old 26 May 2005, 04:48 pm
What you described sounds like what I experienced a few months ago right after purchasing new front tires.
It turned out to be the tie rod ends needed replacing.
Old 29 May 2005, 04:27 pm
I agree with the others, check out the front end.
Also, Look at the front rotors. Both my front rotors warped at 2400 miles. (go figure)
Good Luck!
Old 31 May 2005, 01:30 pm
Droped off GT this morning.they just called and said TIE ROD ENDS BAD, do these go bad often...My 94 chev. hed 92000 miles before any problems with front end, 102000 no problems with my 1981 chev. wagon...Maybe I should have bought a GM car...BOB RENNINGER[:I][:I][:I][:I]
Old 31 May 2005, 01:42 pm
Bob, if you had bought a GM, you would have had loose/broken interior parts, strange rattles, and leaks that are "normal". If you had bought a Ford, the transmission would be worse than a PT, and your car would be different than many of the same year, make, model, requiring hard-to-find parts (many variations). Every make has different problems. Each chooses places to save money.
Old 31 May 2005, 06:08 pm
Look at how the wheels were balanced. If the weights were hung on the rim that could be the problem. YOu really need to use the weights that go on the inside arc of the wheel. I had a problem when the dealership put a new wheel on my 03 GT and used rim weights. It drove everyone nuts why I had the shimmies (the dealer and 2 other tire shops). Finally Goodyear sent me an Amereica's Tire shop and they recognized the problem immediately. Rebalanced the wheel and it was fine
32.9 miles per gallon driving my GT!!! Gary04GT Turbo Performance 29 26 Feb 2011 11:17 am
Please help, front end shimmy survey Boomer Tech & Performance Forum 32 05 Oct 2009 01:54 pm
'03 LE Cruiser for sale with 6,500 miles walstib Classifieds: For Sale/Trade 3 31 Jan 2004 08:58 pm
20k miles per year = extra precaution?? alceryes General PT Cruiser Discussions 6 18 Dec 2003 08:17 am
Tire shimmy solved!!!!!!! elsololobo02 General PT Cruiser Discussions 5 03 Nov 2002 02:39 am
