PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
01 vs 02 Gearing?
Old 18 Nov 2001, 07:28 pm
CTFrank CTFrank is offline
Default 01 vs 02 Gearing?
My wifes 01 Auto turns an indicated 2900rpm at steady 75per, my 02 Auto turns an indicated 2750 rpm at steady 75per. Both have the same size touring edition tires set at 35psi. I have been told that the final drive gearing is supposed to be the same for the automatic equipped PT's. My 02 also seems to downshift more often and sooner on long upgrades. The published final drive ratio for the 01 is 2.694/1 overall. Does anyone know what it is for the 02? Could this be a problem with the computer?
Old 18 Nov 2001, 07:42 pm
flashbk2 flashbk2 is offline
As far as I know there was supposed to be a change in gearing between '01 and '02. This was in response to cunsumer complaints about mileage. I don't know the actual specs but I'm pretty sure this took place. If so it would explain why your revs are lower and it downshifts more.
01 Aquamarine base 5sp,mods-cold air induction,dynomax muffler,rear sills,rear step pad,color matched center console and rear muds w/gold letters,3bl"RETROROD",LIC"FLASHBK2" ,custom seat covers,weathertech rain guards,gold beltline pinstripe
Old 18 Nov 2001, 09:28 pm
skylight's Avatar
skylight skylight is offline
Administrator
According to PT Do It Yourself.net the only gear change from '01 to '02 was with the 5-speed ...
"On the 5-speed changing the overall final gear ratio from 3.20 to 2.80 increased the EPA rating. All transmission gears remain the same."
taken from here:
http://www.ptdoityourself.net/ptchange.html
jody
vB code is On
  Flights | Mortgage | Flights | Cell Phones | Mortgages
