PT Cruiser Forum Car Videos
Custom Wheels
Faulty Engine Coolant Sensor?
Old 30 Jun 2005, 03:48 am
thegoldpt's Avatar
thegoldpt thegoldpt is offline
Send a message via MSN to thegoldpt
Default Faulty Engine Coolant Sensor?
I was on hwy 1 the other day just exiting morro bay, and i hear a chime, i look down at the panel and the coolant light is on and the gauge at cold, note i have been driving for a good 10 mins you would think it would be in the middle. So i pull over in the next town which of all places is harmony, a town with a population of 10?(i think) No gas station, nothing. I turn the car off, turn it back on it starts fine, the light is off, guage at normal. I was all what the %$*! . With it running i flip around and head towards San Luis Obispo to the chryaler dealer. It did not happen again the whole way there, got there, told them what happened and they decided to look at it, they got this: FOUND CODE PO116, FAULTY ENGINE COOLANT TEMPERATURE SENSOR, OPEN CIRCUIT.
They said they fixed it and it was good to go. No problem, get home. 2 days later, i am driving back from Pismo Beach, on 101. I have been on the road 10 + mins and i hear a chime, every curse word i could imangine came out, i was so mad i just drove home. Got home car went off, turned car back on, back to normal no light. Never has happend again. It has been over 2 wks now and not a sound out of it.
[xx(][:I]
Old 30 Jun 2005, 08:22 am
You need an exorcism....
Seems the dealer did not cure the fault. Sounds like either a flaky sensor or a faulty connection that usually is good, sometimes is open...
Old 03 Jul 2005, 09:01 pm
Pan51 Pan51 is offline
i have had the exact thing happen 2 times..took it to the dealer and they said they found no fault codes...once at 20 miles and once at 3200..i just shut it off and turn it back on and its ok...kinda bugs me tho
Old 04 Jul 2005, 03:25 pm
SteelBlueGT SteelBlueGT is offline
Did the dealer put in any new parts or just cleared to codes out of your computer??
Old 05 Jul 2005, 02:55 am
thegoldpt's Avatar
They replaced the parts, i had to leave it there overnight.
2005 Linen Gold 5spd
PT Cruiser Links Moderator
Old 06 Jul 2005, 12:14 am
kevinl1058 kevinl1058 is offline
I have been having the same problem as of late. Topped off with coolant and no problems for a few says, then took my son for a drive to the store and on the return trip temp started to spike. pulled over killed the car and restart it 5 mins later temp drops and holds for about 2 miles then began to spike again. So far I've noticed that the fan wasn't kicking in so I check the realy and realize that it partially out of the socket pushed it firmly in and let the car idle for 20 mins with temp holding. I knwo that it could be the sensor or possibnly the thermostat so I will wait tosee whats next or just run it into the dealer tomorrow.. Kev
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
  Mobile Phones | Remortgages | Wills | Credit Counseling | Send Telegram
