Will stage 2 wastegate off a SRT-4 work.
Old 22 Jul 2005, 03:09 pm
Send a message via AIM to nastyvr6
Default Will stage 2 wastegate off a SRT-4 work.
Besides the new unit from agp is there any other wastegates out there that will work. I have heard about people using the stage 2 wastegate but will it work for sure? Also I have searched no success. Thanks in advance
Old 22 Jul 2005, 05:28 pm
Send a message via AIM to AZ_IceMan
YES. Yes it will....[?] Check out my mods. [8]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 22 Jul 2005, 05:58 pm
yeah I read that in your sig. So why does the agp one not work but the stage2 does? Also this is the wastegate off a srt-4. thanks
Old 22 Jul 2005, 08:48 pm
Doesn't work? AGP wga works quite nicely [?]
So it's just the stock wga off of a srt4? Why would you want to use that? I can understand AZ using it because it's a stage 2 and adj.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 23 Jul 2005, 04:19 am
wow your post is quite confusing or maybe it was confusing what I was asking.. What I asked is if the AGP wastegate off or for a SRT-4 will not work on the PT GT the why or how does the stage 2 wastegate for a SRT-4 work. Arn't the brackets for the SRT4 and the PT GT diff? Also I know AGP offers a wastegate for the PT GT but, it is also 165 dollars. I have a stage 2 wastegate sitting around from my SRT4 that I no longer have. I know quite a bit about the SRT4 but not much about the PT. It is my wifes car. I already have a K&n filter and a MBC. Looking to hold a little more boost to redline it will spike 18 then drop to 11-13 quickly. Thanks in advance
Old 23 Jul 2005, 05:17 am
The mopar wastegate is identical. And yes, mine is directly from a buddy's stage 2 kit before you could even buy the wastegate separately. The AGP is different for the two, they just have different designs on the brackets, thats all. So in summary, YOU need and AGP wastegate made for the PT or just a mopar stage2 wga,
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
Mopar SRT-4 Stage 2 Wastegate WGA SuGamer Stage Turbo Kits 3 20 Jan 2005 10:20 pm
Will 2004 Stage 1 autostick kit work on my.... Lucille Stage Turbo Kits 3 10 Jun 2004 02:14 pm
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
Prison or Work? You decide... Gary04GT Non-PT Discussions 1 29 Jun 2003 04:09 pm
