spring mod?
  #11 (permalink)
Old 08 Aug 2005, 09:31 pm
srtpt,
I e-mailed you the pics.
Ian
  #12 (permalink)
Old 08 Aug 2005, 09:37 pm
right on thanks alot man, does it really make that much of a difference? i think i may try it but first im changing my ic piping, my boost flaucuates way to much already. its weird its like the higher the rpms go the lower the boost goes. pisses me off.
  #13 (permalink)
Old 08 Aug 2005, 11:59 pm
Thats the PCM dropping your boost as you approach redline. With no mods, the boost is programmed to be in the 9PSI area by 6k.
Joe
05 GT HO, Stage 1, AGP WGA, Greddy BOV, 2 Stage WI, K&N CAI, Powder Coated Calipers, Cross-Drilled/Slotted Discs, Stainless Steel Flex Lines
  #14 (permalink)
Old 09 Aug 2005, 01:54 pm
will the map clamp fix the boost dropping at higher rpm? ihope so i just purchased a map clamp last night.
  #15 (permalink)
Old 09 Aug 2005, 04:52 pm
Send a message via AIM to AZ_IceMan
Not really, need a stronger wastegate and a boost controller. [?] The map clamp will just prevent the timing from being pulled and make you lean out a little. Just make sure you're not boosting too high on stock injectors or pcm otherwise you could get bad pinging and predetonation. Too much pinging and you will get a knock and the knock sensor will retard your timing and fuel delivery...making the map clamp useless. [xx(]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
  #16 (permalink)
Old 09 Aug 2005, 06:42 pm
With the "Gheto" spring mod, I get constant 15PSI all the way to redline. stage 1 controls my boost. Also, The Manual trany PT have lower boost schedules than the automatic.
Ian
Stage 2 WGA vs spring mod. turbotouring Turbo Performance 9 01 Aug 2005 01:47 pm
Spring Rates eliminator Turbo Wheels/Suspension/Handling 4 29 Oct 2004 08:57 pm
Spring Meet Antique Auto Show Pictures RetroPT Northeast PT Forum 3 08 Jul 2004 11:47 pm
Spring popped out!!!!!!! turbomangt Turbo Wheels/Suspension/Handling 7 01 May 2004 06:02 pm
Spring Savings turbomangt Vendors & Buyers Forum 0 18 Feb 2004 12:17 pm
