spring mod?
Old 04 Aug 2005, 01:01 am
Default spring mod?
can someone fill me in on what exactly the spring mod is thanks
Old 04 Aug 2005, 02:04 am
http://www.ptcruiserlinks.com/forum/...stment,on,2003
Old 04 Aug 2005, 03:07 am
That's ghetto. If you are serious about your ride then get the AGP wga.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 04 Aug 2005, 03:35 pm
I guess there is always the cheap way to do anything. Will this work without throwing codes on stage 0?
Old 04 Aug 2005, 04:22 pm
Send a message via AIM to AZ_IceMan
short answer is...NO. Any wastegate other than stock will make you throw codes unless you do the TIP mod, which i wouldn't. Better off just going stage 1.
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 04 Aug 2005, 08:55 pm
Thanks for the info which confirms my original idea so it must be right!![8D]
Old 05 Aug 2005, 12:52 pm
Ahh... That Post... Takes me back..... O yes, all the mods are still in there including the spring mod. The only difference is that now I have both of the springs installed. No codes in the PCM at all.
I know that it's Getto, but as long as it does the work, it is fine with me. It takes me less than 30 secconds to return it to stock and less than a minute to install.
I run my car at 15PSI constant and no codes with this setup.
Ian
Old 06 Aug 2005, 02:09 am
IAN, dont U have stage 1 and that is maybe why you dont have a lot of error codes??
Old 06 Aug 2005, 05:05 pm
Stage 1 is mod friendly. But before I had S1 I had my Apexi and the spring mod and I never had a code pop up. But the reason was that I never went over 16PSI when I had it.
Overboost code shows up after 17PSI over three seconds.
Ian
Old 08 Aug 2005, 07:27 pm
thanks for the info but wheni went to the link the pics would not work. does anyone happen to have pics of this mod they can send to me? my email is agressivedsm@yahoo.com
Stage 2 WGA vs spring mod. turbotouring Turbo Performance 9 01 Aug 2005 01:47 pm
Spring Rates eliminator Turbo Wheels/Suspension/Handling 4 29 Oct 2004 08:57 pm
Spring Meet Antique Auto Show Pictures RetroPT Northeast PT Forum 3 08 Jul 2004 11:47 pm
Spring popped out!!!!!!! turbomangt Turbo Wheels/Suspension/Handling 7 01 May 2004 06:02 pm
Spring Savings turbomangt Vendors & Buyers Forum 0 18 Feb 2004 12:17 pm
