Does the PowerAid "vortex" really work?
Old 08 Aug 2005, 07:28 am
Send a message via AIM to sabishop
Default Does the PowerAid "vortex" really work?
HI All,
Well, the title says it all. Does anybody have any experience with one of these "red wonders"?
Does a cold air intake still fit properly with the added space from the adaptor?
Thanks.
Old 08 Aug 2005, 09:38 am
Nope, it's a piece of crap. Save your money and stay away from it.
Old 08 Aug 2005, 02:49 pm
Send a message via AIM to AZ_IceMan
[B)] 10-4. Thats a big dittooo....
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 08 Aug 2005, 04:44 pm
Here is a test you can use. Does it sound too good to be true? Are they offering a small add-on that the Car Manufacturers could have built in and be able to increase mileage? They are under intense pressure to increase MPG, and have done some pretty expensive things to make the numbers. If they could have put in an oil treatment, vanes in the intake or exhaust, magnets on the fuel lines, or anything else for pennies per car, it would have been done BEFORE multi-point electronic fuel injection, extremely tight machining tolerances, Thin-to-thick sheetmetal (a PT first), or any of the many other things that cost hundreds per car. While there are some great aftermarket products, there are a lot of snake-oil salesmen, too. BTW, don't buy from unsolicited emails, either...[XX(]
Old 08 Aug 2005, 11:56 pm
Agreed 100%. From Fitch fuel treatment pucks, to fuel "Ionization" magnets, (fuels can be ionized, but not by passing a $4 magnet) only the look of the snake oil guys have changed.
The products are pretty much the same as ever.
Crap.
Joe
05 GT HO, Stage 1, AGP WGA, Greddy BOV, 2 Stage WI, K&N CAI, Powder Coated Calipers, Cross-Drilled/Slotted Discs, Stainless Steel Flex Lines
Old 09 Aug 2005, 11:54 pm
Crap.
Joe
Agreed
Old 10 Aug 2005, 05:25 pm
quote:Originally posted by purple04
Here is a test you can use. Does it sound too good to be true? Are they offering a small add-on that the Car Manufacturers could have built in and be able to increase mileage?XX(]
Chevy did come out with the vortec head using the "fast burn" chamber, 5.0's use the "Twisted Wedge" Head....
The theory works the application does not, If you could get that swirl effect in the head...yes you will increase hp and mpg...however swirling the air anywhere up stream of the head is worthless.
2004 PT Cruiser GT
5-Speed
K&N Filter, NOS 70 Shot
14.915 @ 92.57 (2.4 60\')
14.54 @ 102.17 (2.5 60\')
New Parts awaiting install:
Apexi S-AFC, AGP WGA, Stage 1, Mopar BOV, \'05 Intake Manifold
Old 11 Aug 2005, 01:32 pm
quote:Originally posted by sabishop
HI All,
Thanks.
These only seem to work once you have pissed away yout money on them. Just about everyone that did swears that they can "feel a difference", it's just that even the maufacturer stated that they could not measure a difference in HP or torque on a dyno.
Old 11 Aug 2005, 02:20 pm
Agreed, but "twisting air" or inducing tumble in the combustion chamber is a completely different thing than twisting air BEFORE the throttle plate or in the intake port. Also, any add-on that 'works' or increases power in both EFI (dry flow) and carb or TBI (wet flow) applications is suspect.
Detail work. check list turbomangt The Detail Shop 9 22 Jun 2006 08:34 am
Will stage 2 wastegate off a SRT-4 work. nastyvr6 Turbo Performance 5 23 Jul 2005 05:17 am
The work of Steven Wright Jimbo Non-PT Discussions 5 08 Feb 2005 01:53 pm
Prison or Work? You decide... Gary04GT Non-PT Discussions 1 29 Jun 2003 04:09 pm
anyone work for a dealership on here?? bobs turbo pt General PT Cruiser Discussions 2 22 Jan 2003 12:02 am
